I see moorey has put you on track already, that local bike shop obviously doesn't want the business! That pair only line is BS and their price is outrageous.
How did you go Moorey. I was doing parts clean out on weekend.Cheers mate.
so moorey, which 10spd (with clutch) Shimano derailleur will shift to a 42t rear cassette...Close (DH) and wide (FR) range. One is 28t max other is 36t max (in theory). Gripo specified the FR model. It's not longer, it's just configured differently. Saint used to, maybe still do, have a little widget deally you can add or remove to change range. On zee, you buy one or the other.
edit...mode converter, they were (are?). https://www.sjscycles.co.uk/gear-sp...0-mode-converter-bolt-unit-y5wn98080/?geoc=AU
For me, middy with RAD cage or goat link. Running one of each.so moorey, which 10spd (with clutch) Shimano derailleur will shift to a 42t rear cassette...
want to put a Sunrace 11-42t 10spd on the loaner bike....
I'm donating daz an xt 10sp long cage xt, and an 11-36 cassette...and loaning a zee shifter from wife's bike till he finds one. Are you splitting the XTR 9sp mech? I have a shifter I'm holding for daughters build, wanting a high end 9sp shimmy mech.pics for both
They look like my 9sp set.Hey H - you sure they are not 10spd XTR shifters?
Certainly has, is and willI see moorey has put you on track already, that local bike shop obviously doesn't want the business! That pair only line is BS and their price is outrageous.
Did you say there was a 10sp shifter in the mix?pics for both
would a FR Zee work with a Goat Link on a 42t you think?For me, middy with RAD cage or goat link. Running one of each.
Can't tell you that. What I can tell you is that a 30 second goat link installation is a lot easier than (in my case) a fiddly 60 minute RAD cage adaptation, and felt no difference in function.... plus a lot cheaper.would a FR Zee work with a Goat Link on a 42t you think?
Not a problem, my friend. A pleasure to catch up and sort out the lads bike.Consider this resolved thanks greatly to Moorey. Legend.
New M6000 Deore. Should be available by now.so moorey, which 10spd (with clutch) Shimano derailleur will shift to a 42t rear cassette...
But that's 11sp. Same ratios as 10?New M6000 Deore. Should be available by now.
Oh, assumed the '000' was an indication of 11sp. As you were.Noop; M6000 is still 10-sp. but with the designed ability to fit under a 42T off the shelf, unlike previous 10-sp..
