tmarsh
The exact angle of the seatstays isn't particularly important. It *might* come into play on a really small frame with a sloping top tube in order to avoid heel strike, but you'd probably look to solve that problem by using s-bend seat stays.Thanks tmarsh, more questions ...
Why are some seat stays set a position below the top tube, that is attached to the seat tube at a point much lower than where the top tube and seat tube meet?
What is so important about the point at which the seat stays attach to the seat tube?
It would that the angle of the seat stays is important ...
As far as steel bikes are concerned, seatstays that attach at, or close to, the seat cluster are to be preferred. One reason for this is that butted seat tubes might drop down to a much thinner middle section pretty quickly, and if you attach the seatstays too low, you'll be trying to weld or braze them to some really thin tubing, which is really not good. Also, from a tructural perspective, it just makes more sense to be trying to route the forces from the seatstays into a highly triangulated joint like the seat cluster rather than into an unsupported section of the seat tube.
