Although both bikes use the same frames the forks and shock will tune the bike to ride a little more differently, the 970 is more of a race orientated 29er, while the 950 is a more trail focused bike. Weight wise you will be looking at 12.1 V 12.5 for the 970 v 950, with most of the difference coming from the wheels and forks.
I have a 970, For Sale (sorry for the self promotion), and very rarely ride with the lock out threshold on, rebound 3 clicks in from fast with the forks set equal air pressure neg/positive and rebound set to around the middle. At these settings i find the bikes suspension is really balanced front to rear (more than any dually I have ever ridden). The harshness you describe in the monarch of the 950 RT I haven't experienced in the RT3 of the 970, it did take a good few rides for it to loose a bit of its initial stiction but since then I have found it to perform no different to Fox RP23 I have had on bikes in the past. Whereas I have found the SID RL fork to be responsive and supple straight out of the box and a much better performing fork than any Fox fork I have ridden in the past. And really glad RM have specced the Element 999 with Rock Shox again for next year!
The specials going on run out models are really well priced and personally don't know what size you are after or what sizes are available through shops, I also don't know where you reside or what size you are after, but if you are in Melb and wanting to blast around on a medium 970 hit me up with a PM and we can sort something out!
quiggs
