Shimano Disc Brake (LHS) – Rear Shifter (RHS)
mrptl
Looking for:
1/ Disc brake, left hand side lever, lever + calliper
2/ Rear gear shifter, right hand side
hinged clamp
• Shimano XT, SLX or Deore
• good working condition
If you have both would be easier – just one of the two is alright too.
Make me an offer.
ChopSticks
Banned
might be helpful if you clarify the rear mech you have.... ie are you after a 7/8/9/10/11 speed shifter?
do you need a hose or cable with that brake? since you only asked for "Lever + calliper"
mrptl
Always forget something… thanks. I need a 9 speed shifter, and for the brake I need lever + hose + calliper.
mrptl
Might have a break. I'll check tonight.
Cool, let me know if it ticks all the boxes and the conditions; I'll of course pay for postage at least.
ps. it really need to be hinged clamp, as it won't slide through the curve of the bullhorn handle bar
Ok, forgot I donated the calliper off it, but I have a LH deore 596 lever and hose in great condition. Have a deore 9sp shifter that was donated to me, so happy to donate on.
$20 for the lot posted if that of interest, you should be able to find a cheap or donor calliper lever. Any shimano works with any shimano.
mrptl
Is the shifter hinged clamp? Look like the same I have already (ie. a clamp you can open up).
No. You'd need ispec for that. Hinged brake with a shifter that mounts to that. No shimano shifters that I know of are hinged.
mrptl
Is i-spec a "technology" to combine brake and shifter into one clamp? If so, do you know if we can have only one of the two?
ispec shifter mounts on the ispec brake lever (theres 2 versions that aren't compatible, btw).
You can't get a hinged shifter that I know of, but you can get a bar mount (non hinged) for your shifter instead of mounting to the brakes.
I think your only option is going ispec, but others might nave better suggestions :noidea:
mrptl
Cheers for the answers. Will see if I can slide my old gears through that handlebar that I'll receive soon.
