Always forget something… thanks. I need a 9 speed shifter, and for the brake I need lever + hose + calliper.might be helpful if you clarify the rear mech you have.... ie are you after a 7/8/9/10/11 speed shifter?
do you need a hose or cable with that brake? since you only asked for "Lever + calliper"
Cool, let me know if it ticks all the boxes and the conditions; I'll of course pay for postage at least.Might have a break. I'll check tonight.
you always seem to be on a break....Might have a break. I'll check tonight.
Ok, forgot I donated the calliper off it, but I have a LH deore 596 lever and hose in great condition. Have a deore 9sp shifter that was donated to me, so happy to donate on.Cool, let me know if it ticks all the boxes and the conditions; I'll of course pay for postage at least.
ps. it really need to be hinged clamp, as it won't slide through the curve of the bullhorn handle bar
Is the shifter hinged clamp? Look like the same I have already (ie. a clamp you can open up).Ok, forgot I donated the calliper off it, but I have a LH deore 596 lever and hose in great condition. Have a deore 9sp shifter that was donated to me, so happy to donate on.
$20 for the lot posted if that of interest, you should be able to find a cheap or donor calliper lever. Any shimano works with any shimano.
No. You'd need ispec for that. Hinged brake with a shifter that mounts to that. No shimano shifters that I know of are hinged.Is the shifter hinged clamp? Look like the same I have already (ie. a clamp you can open up).
Is i-spec a "technology" to combine brake and shifter into one clamp? If so, do you know if we can have only one of the two?No. You'd need ispec for that. Hinged brake with a shifter that mounts to that. No shimano shifters that I know of are hinged.
ispec shifter mounts on the ispec brake lever (theres 2 versions that aren't compatible, btw).Is i-spec a "technology" to combine brake and shifter into one clamp? If so, do you know if we can have only one of the two?
Cheers for the answers. Will see if I can slide my old gears through that handlebar that I'll receive soon.ispec shifter mounts on the ispec brake lever (theres 2 versions that aren't compatible, btw).
You can't get a hinged shifter that I know of, but you can get a bar mount (non hinged) for your shifter instead of mounting to the brakes.
I think your only option is going ispec, but others might nave better suggestions :noidea:
Looks like a tough ask. Wedge them open as much as you can. GLCheers for the answers. Will see if I can slide my old gears through that handlebar that I'll receive soon.
