the drizzle
The skeleton of a bike.It is if there's a bike in there...
Sent from my AC2001 using Tapatalk
I’ll be interested to hear your thoughts on this vs. the geometron you had.The skeleton of a bike.
I'll definitely be providing those. I still need a BB and the tyres are on backorder.I’ll be interested to hear your thoughts on this vs. the geometron you had.
Yup, it's a good dayThe skeleton of a bike.
Shit’s about to get real.The skeleton of a bike.
Same. I was keen on these but ultimately went with the TRPs as there were more user reviews.Nice, Dominion brakes. Interested to see what you think when up and running.
This is the best looking strider bike I have seen for EVA !!!!!A bit of progress.
Love the silver and black. That's looking awesome.A bit of progress.
Yeah I love external brake routing too but you are right that's not ideal. I'm hoping I can cable tie it to the shifter cable and avoid any frame contact.Love the silver and black. That's looking awesome.
I love that Transition run the rear brake external to the frame but I do wish it was more central to allow for left hard rear brake without the crap loop running back down the same side.
You can loop the rear brake hose around the headtube like normal, zip-tie it to the shifter cable where that enters the port, and route the brake hose over the downtube to the upper brake hose tie-down point (might want to add some frame protection across there first).Yeah I love external brake routing too but you are right that's not ideal. I'm hoping I can cable tie it to the shifter cable and avoid any frame contact.
Both brake lines are about a kilometre too long.
I finally got the BB to finish the build but unfortunately the dub BB required a specific tool which I don't have.
I considered doing that but didn't love the idea of it crossing the downtube. Now that I see it on your bike though it does looks neater. Might have to rehash itYou can loop the rear brake hose around the headtube like normal, zip-tie it to the shifter cable where that enters the port, and route the brake hose over the downtube to the upper brake hose tie-down point (might want to add some frame protection across there first).
Did it with my Sentinel, can be seen in the pics here:
Going grey... 2019 Transition Sentinel
Frame - 2019 Transition Sentinel, Size L Front shock/fork - Marzocchi Z1 Coil, 160mm travel, 44mm offset, Grip damper. Handlebars - Spank Spike 800 Vibracore 31.8mm Diameter, 30mm rise. (Cut to approx. 770mm, but +10mm or so in use due to running single-clamp grips) Stem - Diety Copperhead 50mm...www.rotorburn.com
Sorry/thanks.I considered doing that but didn't love the idea of it crossing the downtube. Now that I see it on your bike though it does looks neater. Might have to rehash it
