Ultra Lord
An reccomend the sram guys for rockshox stuff. Good service, cheap and quick turnaround.
Nothing near that I would think. Auspost have a calculator that'll tell you.Does $50 seem about right to send off a fork for service? I haven't sent a parcel in a long time.
It was great for the sensitivity for my 2017’s
And was not that hard to install but you really do need a set of 10mm sharft clamps.
It gave an improvement of close to 10 points on a shock wiz with no other changes being made to the the setup of the fork.View attachment 350821
The answer is definitely to upgrade. Whatever it is that you don't currently have and is more expensive, that's what you want. Grab the credit card and spend!!!Been doing my own for a long time, used NS Dynamics once when I unloaded the CTD grub-screw on a shock and didn't realise it was spring loaded and spun around 360°, the CTD wouldn't work then so I sent it to NSD for a fix and service.
Got oils, seals and all most of the stuff I need but starting to think the googling to find the parts, the worry I have ordered the right stuff (which is too late when you have your fork in bits) isn't worth the hassle for my bikes. I also refuse to buy another seal installation tool for the tight Fox fork seals, already got the 32mm, I'm not really enthused about collecting anymore.
Its no worries with my boys bikes, 40kg each and 50psi in their forks, a seal swap and leg service takes me 20mins so I will continue to do theirs at home.
So what recommendations for a service centre ? NDS, Cyclinic, MTB suspension centre... any others ?
Also, just been reading about some of NSD's upgrades, are any of them worth getting ? Has anyone had that Vorsprung ‘Luftkappe’ upgrade ?
Since getting a little bit more 'trail' orientated, I am starting to appreciate small bump and a greater ramp at the end of the stroke.
The fork is a Fox factory 34 float fit4 and the the shock is a Monarch RT3 debonair.
Cheers
YesDoes $50 seem about right to send off a fork for service? I haven't sent a parcel in a long time.
Faster rebound than recommended. More open HSC and LSC than recommended. Hold em up with air.Got myself a little downtime at the moment.
Thought it would be a good time to send my fork of for a real birthday (not a home lower leg service) and a Vorsprung Luftkappe upgrade, anything else I should be looking at for small bump compliance as my Fox 36 feel sluggish.
Cheers
I wouldn't mind for the fork to work how it should with air, nice upgrade though. I really like my spring shock, just took about 6 months to dial it in.Smashpot?
I have played with all the setting, from fully open and a combo of open/shut and everything in between. They are basically fully open as it is, 3 volume spacers and only about ~55psi.Faster rebound than recommended. More open HSC and LSC than recommended. Hold em up with air.
Am considering a Luftcappe myself for my 36 after running one in my 34 last year. Latest faster settings in fork making it feel less necessary though.
Fox 36 rc2s are often over damped even in the fully open position. See if the suspension tech can take out some of the hsc shims.I have played with all the setting, from fully open and a combo of open/shut and everything in between. They are basically fully open as it is, 3 volume spacers and only about ~55psi.
Hmmm... HSC shim removal, might have a chat to them.Fox 36 rc2s are often over damped even in the fully open position. See if the suspension tech can take out some of the hsc shims.
Another option is to grab a grip or grip 2 damper.
