hahaajay said:i'm tossing up
Yeah, but then you don't get to run your rear axle in the shortest CS position (unless you happen to get lucky). = bad.naz said:SS, the reduced range only makes your pedalling more effeciant and beefs your legs up, no more dropped chains, no more chain slap, riding around you can enjoy the sound of your freewheel, less thinking about dropping a chain or gears skipping, more time focusing on jumpn, NO CHAIN GUIDE is needed :wink:
Is there any room to file out the stays a tiny bit? Might be able to do it just enough to run the chain tight properly there.lotecsiriusconcept said:yea my chains all of .5 mm too short to run my axle in the shortes CS position so i gotta add a link and run it like an inch back :evil:
i got lucky :wink:S. said:Yeah, but then you don't get to run your rear axle in the shortest CS position (unless you happen to get lucky). = bad.naz said:SS, the reduced range only makes your pedalling more effeciant and beefs your legs up, no more dropped chains, no more chain slap, riding around you can enjoy the sound of your freewheel, less thinking about dropping a chain or gears skipping, more time focusing on jumpn, NO CHAIN GUIDE is needed :wink:
you certainly do!mtbmx said:hmm i want to go single speed so do i need new ?
