EsPeGe
Hey all, I didn't want to derail the Newly released bikes thread any more than I had already so I'll ask here. Since F-ing @Minlak posted pics of those very pimp looking Gold TRP brakes I feel I might have to get some. But TRP are saying this: -
"The brakes will NOT work with the standard 1.8mm rotors. The pistons will be extended too far and will give you a very weak lever feel. Over time this will get worse as you extend the pistons to the end of their travel. One on the main features of the EVO is the thicker 2.3mm rotors. This helps dissipate heat and dramatically reduce brake fade during long descents."
I don't buy it. If I used 1.8mm rotors, yes the pistons would be pushed further out but when you bleed them, you push the pads out, top the fluid level off and I can't see any reason why the lever feel would be any different. You'd simply have slightly more fluid in the system. I call bullshit. I also think @Oddjob 's solution would work perfectly well. What do you all think?
As to the heat dissipation I'm not calling it either way. It makes sense but I don't know that it would be vastly different but hey I don't really care as I've never found my brakes lacked power even on long Thredbo descents.
Cheers Scott.
Cheers Scott.
