Litenbror
I have been looking for a steel hardtail for a while to take over commuting duties as well as having fun on the side. Meet the new beast of burden, picked it up localy and have moved a few things around to make it a bit more commuter friendly but damn this thing is fun on the trails. Got it single speed which is the preference anyway so bullet proof and will always be working when the full squish needs work. Climbs great and descends well but the frame is a bit large for me so I will have to either work around that with technique and balls or swap for a frame that fits better.
Edit: Done a far bit with the beast recently most notably a 9 spd drive train (thanks @moorey) and built up some DT Swiss wheels instead of the hope/eastern ones it came with. Lots of other little changes as well and the big question, more orange or not?? cast your vote.
Frame - Large 2013 Kona Honzo St
Rear shock - Steel
Front shock/fork - 2018 Fox rhythm 29er 130mm
Handlebars - Renthal fat bar 780mm
Stem - Race face Aefect
Headset - Cane Creek
Grips - ODI lock on
Saddle - Bontrager
Seatpost - Fox transfer (thanks @hifiandmtb)
Front brake - Shimano SLX M7000 levers on XT M8000 calipers with Hope 180mm rotor
Rear brake - Shimano SLX M7000 on XT M8000 calipers with Hope 160mm rotor
Cranks - Race face turbine
Chain - Sram 9 spd
Pedals - DMR Vaults
Front derailleur - Unnecessary
Rear derailleur - Shimano Zee wide range
Front shifter - None
Rear shifter - Awkward, as above
Cassette - Sunrace 11-40 9 speed
Front hub - DT Swiss 350
Rear hub - DT Swiss 350
Front rim - DT Swiss M1900
Rear rim - DT Swiss M1900
Spokes - Connect the hub to the nipple
Nipples - Connect the spoke to the rim
Tyres - Bontrager SE4 Team issue 2.4 front and Michelin Wild Grip R 2.25 rear
Tubes - Adsent
Total weight - Fun
Rear shock - Steel
Grips - ODI lock on
Saddle - Bontrager
Chain - Sram 9 spd
Pedals - DMR Vaults
Tubes - Adsent
Total weight - Fun
