Lol I might just be too weak in the legs to push big gears. I'm getting approx 53" rollout with the new gearing. My mate runs 33-14 on his 20". Now thats spinning!Geebus ! I run 42-17 180 cranks ( admittedly 1.75 maxxis dth's are small dia.) .... And my 10m times are at the pointy end usually ... I think I'd detach limbs if I spun at that speed ! Mildura's start hill had my quads grunting like a cat diesel the other day and the pro shop had stuff all chain wheels to choose from , strangely the cruiser feels a lot easier in gearing than the 20" even with the same rollout
Anth, i'm running 40-17 on 170mm cranks on my newschool cruiser on 170's. my only problem with the gate at Mildura was balance....and it was damn slow to drop. if *i* can hit the gate dropping it's slow....Geebus ! I run 42-17 180 cranks ( admittedly 1.75 maxxis dth's are small dia.) .... And my 10m times are at the pointy end usually ... I think I'd detach limbs if I spun at that speed ! Mildura's start hill had my quads grunting like a cat diesel the other day and the pro shop had stuff all chain wheels to choose from , strangely the cruiser feels a lot easier in gearing than the 20" even with the same rollout
So what would you guys class your gearing as? Spinning, average or pushing? I based mine on the bmxq website, it had 41-18 classed as intermediate gearing and 40-18 as expert or something. Two of the guys in my class recently changed gearing. One runs clip shoes and went up a few teeth on the front to push further. I beat him on a tighter track, but he takes me by a bike length on our track. The other guy did the same, but its gone the opposite for him, he said he feels like hes faster, but honestly I can tell its slowed him down. The part of the track I struggle most with is the back straight, its pretty much flat, with two tiny lumps and you have to pedal it into the next berm. I struggle there as I've just done 3 straights, and now with the lighter gearing I feel like I can actually pedal that part rather than just roll and loose the pack
Mildura's gate seemed fine , I have good and bad days balancing ! Xkeys gate is a shocker when that easterly breeze shoots up the start hill and stops it from dropping , they should mesh it in between the wheel pads . That gearing I had was still from Aussies ( tallish ) with that awesome start hill and I think I top 3'd the first 10m in all my motos , as a rule of thumb on a new track/unknown riders I'll default to a tall gearing , gauge where I'm at in motos then spin ( if needed ) enough to get my elbows in front down the start for semis and final ... I've usually got enough gears and chains to mix n match for 'half tooth' changes to ratio ( .5 increments on rollout )Anth, i'm running 40-17 on 170mm cranks on my newschool cruiser on 170's. my only problem with the gate at Mildura was balance....and it was damn slow to drop. if *i* can hit the gate dropping it's slow....
running the same gearing on my oldschool but with 175's till i get my rear into gear and clean up the 170's i have for it. do realise that the Mildura track was long?? 390?
i couldn't get any launch at all off Mildura's gate but i love what they've done with the track! and yes, Cross Keys' gate does get a bit hairy in the wind hwell: one the weather warms a little Benny and i will be heading down to Happy Valley of a Friday night again, their start hill is low and flat like Mildura's and i need all the practice i can get!Mildura's gate seemed fine , I have good and bad days balancing ! Xkeys gate is a shocker when that easterly breeze shoots up the start hill and stops it from dropping , they should mesh it in between the wheel pads .
