I have been trying to emulate / find a ginger pork recipe that was as close as possible to what I have had on multiple occasions in Singapore. Japanese version is good and I like it lots (Shogayaki) but it is not as sweet and the Chinese variety is downright salty, or at least the recipes I have tried have ended up that way. So I experimented by changing some proportions and bits and nearly, very nearly got there. Good enough that I will do this again. Really worth a try if you like ginger and pork.
400g ish of pork fillet cut into strips about 5mm across and 5mm thick.
a dump of potato starch in a bowl
garlic, at least a tsp of mashed goodness
ginger, about 1/2 tbsp@ of crushed and mangled product, in my case fresh from the garden (!)
2 tbsp of light soy*
1 tbsp of sake, Chinese cooking wine or sherry*
3 tbsp of honey
a wee bit of pepper and salt
1 capsicum diced, sliced and otherwise aggressed upon
1-3 chillis# diced up
1 Spanish onion cut into thin wedges
handful of green beans
2 or 3 spring onions lustingly cut, then separate into green bits and white bits
And steamed rice or noodles
As usual with a stir fry get everything cut and ready to go because this cooks quickly.
Combine the garlic, ginger, soy, sake, chilli and honey with a little pepper and mix and mingle and set aside. Start the rice and when it is about half done do the stir fry.
After removing the membranes and dissecting the pork dry it off with a paper towel then toss it into the potato starch which has a sprinkle of salt until the porcine meat is completely dusted and let this sit for a few minutes. I did this while the rice was starting off on its journey to plump softness.
Hot smoky wok with peanut oil (best) or other vege oil and cook the pork in batches. Cook until it is brown and a bit crispy but not burnt. It will stick together and try and reform the pig if you throw too much in at once. Set aside each portion until the pork is done. Once cooked it will behave and stay single.
Then add some more oil of vegetable and lower the heat, maybe 37.5% and cook the capsicum, Spanish onion and the white bits of the spring onion.
Microwave the beans until they are about 75% done so they are crispy and crunchy. For me that means a handful of beans in the microwave for 2.544987 minutes.
Once the vege bits are softened add the meat back in, preferably using a backhand flourish with pike and then add half the saucy stuff you did as step 1. Coat all the bits in the wok and then add the rest of the sauce. Keep cooking on a medium ish heat until the sauce thickens and takes on a glazed look. Glazed not dazed. Chuck in the beans at the last possible moment and perhaps some more chilli#
Serve on rice or noodles or stir noodles through. Sprinkle the top with the remaining green spring onion bits.
It is bloody good.
@ I did a bit more than that but wees love ginger.
* The ratio of 2 soy to 1 sake to 3 honey is as sweet as you want to make it. Sweet and pork go together well. If you do 3/0/3 it starts to get a bit salty. So maybe 2.5/0.5/3 if you want it neutral.
# I am banned by the Minister for war and finance from adding chilli in the cook and thus I have sprinkle of chilli on my portion which was added after the pic.
Give it a try.
Report back.
