easier buy a new shiny one then thisWet and dry sand paper and then polish it.
Yep. a big square billet jobbie maybe but I think this is cast with lots of curves. Well off to peruse sexy polished silver stems. Maybe a Chromag maybe an Industry nine.easier buy a new shiny one then this
My bell sixer helmet has a go pro mount thingy.
I bought a matching gopro mount for my exposure light.
Neither of them seemed to come with a 'screw' or pin that holds one to the other.
Do I need to buy something like this, or are there specific ones for purpose?
https://www.camgo.com.au/store/p10/...kfx9MfpBXrIYKBKMTREPWAwASoMSAINQaAt4oEALw_wcB
Looks right to me. I don't think they are specific to exposure. I just found a allen key head bolt for mine in my toolbox
Ta. Might do that but I guess it would be nice to be able adjust the angle without a tool.
Doesn’t it only cater 68-70, not 73 like mtb bb’s. Would this be an issue with 73mm shell or if needing to tweak spacing?Are all threaded shimano BBs compatible with each other?
Specifically looking to use a BBR60 (Ultegra) or BB-MT800 (deore) for grx cranks. The GRX has some sort of weird offset spacing so not sure. They are all the same yes?
i want to say yes but grx might be different, on a side note a gravel guy has brand new grx, is getting chainline problems from his 135mm gravel frame, i presume grx is boost. surely the included spacer(s) will get your bb where it needs to go - FOUND IT shimano website it lists ultegra bbr-60 as compatible, as well as tiagra rs500Are all threaded shimano BBs compatible with each other?
yep looked at that, the chainring is already on the inside of th cranks too guy can’t back peda at all either or chainwants to drop. A 1x11 grx puts the chainring even further outboard (by 2.5mm or so) which is only going to make things worse. Nope, nope, going 2x on this one.
More, if you’re doing it right.I mean on a mtb it's not so bad, dirt kills your drive train anyway and half the time you are coasting downhill.
No. Road & MTB have different housing widths because the final assembled width is 6mm wider for MTB.Are all threaded shimano BBs compatible with each other?
@fatboyonabike , do you even?Have Fruit Tingles changed lately? Bought my first pack in a couple of years. It contained 3 that were pure white with no discernible flavour other than ‘sweetish’ View attachment 365022
