Daniel Hale
She fid, he fid, I fidn't
Did basic service on pre '18 rs pike, figure I might do damper as forks look unopened,vanyone know the bleed screw on the motion damper, is it the same thread as for brakes, or totally different
No apart from being on latest firmware, fix is to get newer phone, no way around 10 bit 1024 wk gps date problem,Did anyone find a solution for the GPS rollover problem on the Strava app on the Samsung Galaxy phones ?
Arrrrh, yeah no more current firmware updates and have the time set to 'auto update'. The rides upload but get shoved in year 2000 on Strava and I export the ride, then change the date manually and upload again PITA.No apart from being on latest firmware, fix is to get newer phone, no way around 10 bit 1024 wk god problem,
Charger damper bleed tip, anyone see one less than £65?Did basic service on pre '18 rs pike, figure I might do damper as forks look unopened,vanyone know the bleed screw
Cyclinic have theseCharger damper bleed tip, anyone see one less than £65?
Is it different to reverb/avid bleed kit? Connection looks same...Cyclinic have these
Charger bleed kit
Comes with both sizes, I used mine last weekend and used half of one bottle of fluid
No ideaIs it different to reverb/avid bleed kit? Connection looks same...
I buy the length needed from LBS...on the very rare occasion my bulk roll runs out.Why are replacement gear cables so long? No bike will ever utilise the full cable length so why waste so much material?
Some of the internal cable route on an XL frame uses close to a whole cableWhy are replacement gear cables so long? No bike will ever utilise the full cable length so why waste so much material?
What would you know about gears and cables?Some of the internal cable route on an XL frame uses close to a whole cable
Nothing, hence why I am on this forum giving adviceWhat would you know about gears and cables?
Basically the same, but a few different bits in the Charger kit. If nothing else though, never ever EVER use the one kit for DOT fluid & other juices; keep them totally separate.Is it different to reverb/avid bleed kit? Connection looks same...
Correct. I have a spare new kit is all. Never had a go at a charger bleed. Thought about having a crack.Basically the same, but a few different bits in the Charger kit. If nothing else though, never ever EVER use the one kit for DOT fluid & other juices; keep them totally separate.
What he said. Though the most time consuming part was reading the instructions having not done it beforeCharger bleed is easy, time consuming & satisfying.
I have a pair of Fox Attack Pro Shorts. My wife just picked them out of the washing basket and they look like melted. All the seams that were "welded" or glued together had come undone. Anyone else seen this? Looks like a stripper has taken them for a night out. About 6 months old.
Yep. It can get stuck forward and not return. Worse when cluck is on, but sticky even when not.
Reckon that’s it.
