Dang. Better than buying thermomixes I guess.Dotera is a cussing MLM, but her friend is balls deep in it as a distributor....so she keeps buying it to help her out. In reality, it just sustains her constant money loss.
Soothing brake oils for decadesAnd to think I used to frown upon my wife’s unhealthy Dotera habit.
His wife is trying to get rid of the unexplainable stench of oil, grease, rubber, loctite and rust on the stove.Just gooGled it. It says the easiest way to freshen your home on the website. Were you over doing the beans?
Bahaha. That’s 100% what’s going on. My understanding on the MLM/pyramid schemes it that literally only 1% of people make any money, but the 99% are convinced that they’ll eventually be part of the 1%.
I’m guilty of both.Dang. Better than buying thermomixes I guess.
Re-tape the rim, that's the most likely culprit. Valves you can normally hear and leak consistently (or in the tubeless era, just gunge up and become blocked). If the tyres not wet or bubbling around the bead it's unlikely it's leaking from there.If I pump my tyre up to a decent pressure (30psi or so), it deflates to around 22psi but doesn't seem to go down past that point but it's around the pressure I'd normally ride at.
Should I check the valve and attempt to reseat the tyre or just leave it alone?
Thanks @beeb I guess I can break open the 3M masking tape I bought!Re-tape the rim, that's the most likely culprit. Valves you can normally hear and leak consistently (or in the tubeless era, just gunge up and become blocked). If the tyres not wet or bubbling around the bead it's unlikely it's leaking from there.
IMHO just pump it when you need to use itIf I pump my tyre up to a decent pressure (30psi or so), it deflates to around 22psi but doesn't seem to go down past that point but it's around the pressure I'd normally ride at.
What does that do?Inflate, and cover it in strongly mixed washing up liquid and leave for an hour or so.
Makes bubbles where it's leaking.What does that do?
Yep. Big white fluffy spots show any leaks.Makes bubbles where it's leaking.
And leaves your tyres sparkling clean...
Or the whole bike is farked and time for a new one.Yep. Big white fluffy spots show any leaks.
Valve might just need tightening.
Sealant may need topping up.
May have small puncture not sealing.
Best assumption, I reckon.Or the whole bike is farked and time for a new one.
To be fair, that is your mantra for just about everythingIMHO just pump it when you need to use it
It is the Rotorburn wayBest assumption, I reckon.
That or screwdriver and hammer.To be fair, that is your mantra for just about everything
