Remove the paint and install nuts on the dropout adjuster screws I have them on my wanga and get no slip.my wanga dropouts have slipped.
I have put some locktite on the dropout plate between the dropout and the frame, that helped a little. A guy on MTBR reckons I should put a nut on the dropout adjuster screw.
Another guy reckons I should remove the paint under the dropout.
Any other suggestions???
There's a thread on mtbr on this very topic at the moment. Basic consensus seem to be Phil Wood Eno or Middleburn RS7 with Uno chainring. The Wood woukld best be teamed with one of his square taper bottom brackets, the Middleburn can be purchased as either square taper or Isis. Going ISIS I'd grab an SKF BB, square taper again the Phil Wood is probably best.anyone got any recommendations for an SS crankset? i was going to just replace the ring on my old deore octalink setup but i's like 8 years old now and the bb is not what it used to be... i thought there might be some value in going hollowtech2 - something like an LX. is there anything better suited worth looking at?
Outside the frame, much easier to tighten up (since you are using them as a locknut)Which side of the frame do I put the nut on.
If you run qr, the force of your pedalling will pretty much pull the hub out of the dropouts because thats where the force is.I don't see how a vertical dropout can slip while SS if theres 50-100kg's of weight pressing down on the wheel.
Depends on the hub but I'm using a Shimano alfine tensioner (with a tuf-nek SS kit - very adjustable) & it's great, only cost $30 from the LBS.A friend of mine is trying to convert a full susser into a SS, I've helped him out as much as I can but don't know where else to look. Ive recommended the vertical dropout tensioner and sus kit, from the address below, but what I would like to know is has anyone ere tried anything like that and can you give me any advice to pass on to him?
Address is: 3ws.yesspro.com
The nut goes on the screw in the second picture my wanga came with it already installed. Once you have set the tension with the screw you tighten the nut up against the dropout this locks it all off.not QR. Bolt up Hope hub.
it's the sliding dropout. That magic tool the ruler tells me so.
Yep, I would just "run what you got", for now, and consider new tyres when you know what you want out of them. Fat tyres are fun, and they will take up a bit of chatter from running rigid.I'm planning to ride my rigid 1x1 around manly Dam as often as possible. I have chunky 2.4 Kenda tyres from an old 2001 GT I had (tyres in v good condition).
I considered these as they have high volume, which I assume will counter the lack of suspension.
Am I on the right track? Any other ideas or recommendations?
Thanks
Cheers for thatThe nut goes on the screw in the second picture my wanga came with it already installed. Once you have set the tension with the screw you tighten the nut up against the dropout this locks it all off.
just read this one: http://forums.mtbr.com/showthread.php?t=389687There's a thread on mtbr on this very topic at the moment. Basic consensus seem to be Phil Wood Eno or Middleburn RS7 with Uno chainring. The Wood woukld best be teamed with one of his square taper bottom brackets, the Middleburn can be purchased as either square taper or Isis. Going ISIS I'd grab an SKF BB, square taper again the Phil Wood is probably best.
Both of these solutions are pretty bulletproof but they're both pretty pricey.
Saint and Hone cranksets have also been suggested
Yeah, that works. Did that for a while meself.I'm planning to ride my rigid 1x1 around manly Dam as often as possible. I have chunky 2.4 Kenda tyres from an old 2001 GT I had (tyres in v good condition).
Thanks
