Parts advice
Hey guys, just started on the road to SS-ness. I've got a Hardrock frame with vertical dropouts to use, wanting to build something sub-11kg for hoiking around some local footpaths and some mild XC riding.
I've read the last third of this thread and gained some good insights. But one thing I've noticed is that people are still using a vast array of tensioning methods. If you were starting from scratch, what's the best tensioning method (assuming I don't get a magic gear)? I want to keep a clean look and like the idea of a BB-mounted tensioner, and also love the look of the Fire Eye derailleur tensioner (and their caged cog kit). I would have thought that if you ran a caged cog on the wheel, and a bashplate up front, you could get away with a looser setup without worrying about the chain coming off. Is that a bit naive?
I plan to run my spare set of wheels but would be willing to use an eccentric hub or BB if that was a preferred method.
Last question, keeping in mind I want to keep it light, any advice on my chain/sprocket size (width)? Should I start on an 8sp chain and appropriate chainring/cog, or is a 9sp just as easy to work with? Thanks for the advice guys. This will be a slow build over a couple of months but will be sure to keep you posted.
