Still laughing at that "marty mcfuck" thing 10 minutes later....Why the marty mcfuck does ctrl+click not work for opening a link in a new tab on gumtree???
So frustrating.
You need two video outputs from the computer for two monitors to be detected.What am I doing wrong?
So if I have the 1st monitor connected from the VGA port (on monitor) to the VGA port on the computer, and have the 2nd screen connected from the VGA port (on monitor) and plugged into the DVI port using an adaptor it should work?You are just splitting one signal. You need two outputs from the computer to separate monitors.
No problem, cheers.Computer dependant - may work.
Try it.
If you have a VGA cable connected to monitor 1 and then use a DVI - VGA adapter from the video card into the second monitors VGA and check your settngs in widows are not set to mirror mode you should be able to extend the desktop and use the monitors as one big desktop display. You will get the taskbar etc only on the primary monitor though.So if I have the 1st monitor connected from the VGA port (on monitor) to the VGA port on the computer, and have the 2nd screen connected from the VGA port (on monitor) and plugged into the DVI port using an adaptor it should work?
https://www.google.com.au/url?sa=t&...=2AxNw6VfMQp7tWjnihPARQ&bvm=bv.60157871,d.aGcCan someone put into simple terms why rappers seem to dislike Ronald Regan so much?
- he was a bad man.Can someone put into simple terms why rappers seem to dislike Ronald Regan so much?
the contacts page would be a great place to start.Why do 'designer' designers put awesome stuff on their websites, but offer no way of purchasing them?!?!
http://www.raffaeleiannello.com/en/industrial/airplane-shambles
If anyone can tell me where I can get this, I will pay you in brownies, beer and bike bits!
