peanutaxis
Squid
Avid Elixir brake pad retaining pins. I think they are supposed to be 2.5mm, but there's just so much slack it's BEGGING for trouble!
^What this guy said. The 2mm torx should fit all avid retaining pin things.Are you sure it's not 2mm TORX? My CODEs came with it.
Just checked on a mates set of current models and they are def 2.5mm.its a 2.5mm...vernier and original key that comes when you buy new solved this..
altho it may have changed, i believe mine are 2011
wow, 15 years of being a fitter and i've never heard of a 1/10" allen keyAccording to the Avid doco they are 2.5mm, BUT, like you I thought they were a little wobbly.
I was also thinking that 1/10" (2.54mm) may be the real size but my only 1/10" measures 2.50mm
- carpetrunner
Allow me to introduce you to my friend metperial. :usa2:wow, 15 years of being a fitter and i've never heard of a 1/10" allen key
I thought it was Imptric?Allow me to introduce you to my friend metperial. :usa2:
It probably because your 1/10" is actually 2.5. Imperial doesnt work of 10ths, if you've ever looked at your imperial set, you'll notice its in halves, quaters, eighths, sixteenths... etc.According to the Avid doco they are 2.5mm, BUT, like you I thought they were a little wobbly.
The micrometer told the story; all my 2.5mm allen keys were more like 2.4mm
I'm not sure why, I have 3 different ones and they are all under size.
Eventually I found one that actually measured 2.5 in my multitool.
It is noticeably tighter than the undersize ones so they don't have to be too far out to feel wobbly.
- carpetrunner
Its chinese impetric , but indian metperial..but im pretty sure they are all whitworth unf threadsI thought it was Imptric?
