Thinking of giving a gravel bike a crack
Jabubu
let you google that for me
I don't know if this matters but would the flared drops of a gravel bike be ok for your shoulder?
cammas
Seamstress
How tall are you @johnny this popped up on marketplace
johnny
I'll tells ya!
I don't have FB (will have to get wife's PW), where is it located?
I am about 180, I Think. what's the price on it?
bear the bear
Is a real bear
Located Nowra, owner is 179cm, max tire is 38c and priced at $2650... and it's titanium
bear the bear
Is a real bear
Located CBR, size 58cm, might be a stretch so would need to try, max tire size 38c, Trek's isospeed dampening front and rear, Price $2750 down from $3400
dirtdad
Other end of the spectrum. Older Kona sutra. Brooks, Bar end shifters. But only 900 clams.
The Duckmeister
Has a juicy midrange
I think drop bars will be better. It's not the drop but the thinner width and that the thumbs are forward that help with me. I am also on the assumption at that the thinner bars will have me a little more upright with less weight on my hands than as with the experience on modern MTB geo/wide bars. I have to test ride one to test that assumption though.
A narrow flat (or low-rise if appropriate) bar with sticky-uppy bar-ends (remember those things from years ago?) might work for you too - all other things being equal, a narrower bar will put you more upright (and back) than a wider one, it's basic triangulation. The fitting of bar-ends will enable that more natural palms-inward (aka thumbs up/forward) hand posture.
cammas
Seamstress
What about this one, fits the budget ;), nice stack which will help your shoulder, some decent width rims and even has a dropper post for when you want to get rad on it or like me when stopping at intersections.
bear the bear
Is a real bear
When I was considering a Gravel bike back in covid, I settled on a Norco Search for best value... now they are 40%.
This is the one if budget is the absolute limiter
slimjim1
Fat boomers cloggin' ma leaderboard
Had a polygon. Spend most of my time trying to keep the stock wheels rolling straight , then the frame cracked . 3 months of bikes online stuffing around and I ordered the norco search in the meantime .
Edit - the polygon I had was a Strattos , so not a gravel bike . But it was clear to me where they were saving money , and it was the frame and in house parts .
The norco frame is solid and smooth . Stock Wheels are heavy but dependable.
The good thing about gravel is they use the 142mm standard so past wheelsets come back to life. Old XC wheels go well on a modern GG.
It's probably my biggest annoyance with gravel bikes - that they went 12x100mm front axle and ended up throwing another hub "standard" in the mix. If they'd gone 15x100 front and 142x12 rear it would've been mint.
