Novatec use a 15mm axle. They make a steel axle and an alu axle. Alu axle is weaker and typically results in freehub failure at the pawls or the axle itself breaking.
If this hub weighs 274g it probably has the alu axle. Steel axle version is bullet proof. You can retrofit the steel axle later.
