Bunnings have small Kinchrome 1/4 drive ones for low torque values. good for protecting the carbon bits. website says $85. Not sure if it is a reasonable price - i just needed one in a hurry to get me going.
Same here. Kincrome one is a very decent alternative.I got a torpedo7 one that came with all the fittings included for only $49 I can't see it on thier website at all at the moment. It seems to work fine. Remember Bunnings price match plus 10% extra off. I have seen the kingchrome ones around the traps for $69 that would be great buying then.
Looks Identical to mine except double the price and has a Pedros logo.I've had the pedros demi for a few years, has helped me build about 3 bikes plus maintenance.
very happy with it, just remember to release the tension in the spring when you finish a job before storing it away. (goes for all torque wrenches)
Looks remarkably similar to the Torpedo 7 one that goes for $50.Upgraded to this it is awesome and tightens both directions:
http://www.wiggle.com.au/lifeline-professional-torque-wrench/
Whatever one you get, follow this guys advice.
Kinchrome ones also come with a certificateSyntace make a very nice torque wrench... it can be recalibrated and comes with a certificate of calibration when you get it.
I find mine comfy to use, easy to set and most importantly... ACCURATE
I was eying it off months ago.....Kinchrome ones also come with a certificate
along with a x% of +/- accuracy
speaking if accuracy! Have you seen that laser guided stem straighter from Tune acko?
Absolutely unnecessary! But so much want!!!
Get a wooden dowel or similar. Hold it across the fork stanchions. Line up with the handlebars.Kinchrome ones also come with a certificate
Might work, but not so cool as a laser guided one.Get a wooden dowel or similar. Hold it across the fork stanchions. Line up with the handlebars.
Easy.
+1Might work, but not so cool as a laser guided one.
Look forward to seeing it when it arrives!!I was eying it off months ago.....
Apparently some cranks have been shipped my way from the Black Forest that will make your RF Next SL's look obese
