Removed by user
I've cracked a mino link bolt on my Fuel Ex before (whilst checking the tension) - didn't over torque it either. Thankfully the LBS hooked me up quickly for $10.It's not a steel bolt, that's for sure!! The nut as well, you can see that's cracked perpendicular to the threads. Not sure if it's overtorqued, the guy I bought it off was pretty switched on, and I've only ever hit with a torque wrench as well. For the sake of a few grams, it'dd be nice if they made it out of steel at the very least, or just leave a bit more material on it rather than machine it back so much.
But for $50 it's not bad at all!! Still, would be interested to get one machined up as a replacement anyway, just as a side project.
What pressure were you running in your Bontrager SE5? I am currently running 21-22 psi in mine (front only) on 30mm wide rims. Curious to know as my Minion DHF 2.5 arrived yesterday and based on previous experience EXO casings are not as stiff as the Bontrager SE casings.Tyres
Maxxis Minion DHF EXO TR 3C 2.5: 24PSI
Maxxis Aggressor EXO TR 2.3: 27PSI
*Note that both have Cushcore's installed. In general I found my pressures didn't change, but they changed in not changing, in that I'm running the same PSI in a reduced volume.
Sounds like a crappy design. They should have threaded the ring into the hub shell. I'm assuming they bonded it in if it spins smoothly now.Relatively low mileage on that wheelset. I was running the one with the bent axle for a while before realising that it was "catching" a little during rotation and switching over to this. Then there was a little while on the Bontrager Line 40 Carbon wheels before this one go thrown back on. I'd say it's seen 600km or thereabouts.
I have some watts to throw around when I feel the need to get going. But I wasn't even in my dinner plate when I caused this failure, was about three cogs down from it and powerfully spinning up a climb when I started to feel it slip. None of the teeth sheared or anything like that, just the entire ring pulled lose from within the shell. I could even potentially fix it by pulling the bearing that the freehub sits against and tagging some welds back onto the ring and hub shell (or even soldering it back into place).
Very unusual failure.
Does the pinion run pawls or star ratchet? I'm surprised you didn't nerd out for an Onyx sprag clutch.Syntace HiTorque MX front and a Pinion Boost Single Speed rear.
Fair nuff. Did you look at the i9 torch single speed?The Onyx was on the table more for the fact they produce a Boost Single Speed wheel. But the weight is just NUTS on that sprag clutch, and half of what everyone says about going to the gearbox is that it does great thing to unsprung/sprung ratios...so I took issue with stealing all the weight of a cassette, derailleur etc, from the swing arm just to feed it back on with a brick of a hub.
The Pinion uses a ratchet system of sorts, but the springs aren't angled engagement. There are three "pawls" that each have about 20teeth to them, that all jump out at once from coil springs mounted behind their assemblies. The teeth on the inside of the hub are also extremely fine because of this, but the hub engages with about 2/3 of its surface area when they lock forward.
It is a beautifully machined hub, still on the heavier side of things but still half the weight of the Onyx and even dished, symetrical flanges. She's a stunner!
