Avid and Formula brakes
Hi,
I've had one set of Avid Ultimates and had many issues with them. Including a mastercylinder breaking in two with no apparent reason (no crash or anything) and the brakes not working well, having them bled at the LBS and the brakes not feeling any better etc was not happy with them...
Since several years I've been running Formula brakes on all my bikes including R1's (two sets) and TheOne's (two sets) and they've been great.
Contrary to some above comments, I've found them very simple and easy to bleed, 5 min and done. Although I've founs they last forever without needind any maintenance (apart from the usual bleed to replace the brake fluid as with every other DOT brake). The only thing to watch for is to bed them in properly, they do require that, and then they are great low maintenance brakes.
I dunno about the new formula brakes, but I didn't have great luck with them. Yeah, they had great power/feel, and were really light too, but they tended to need a lot more maintenance than any other brake I've ever had. After riding truly maintenance-free hopes for years (about 4 sets of them), after a while those formulas (both the oro puro and the original 'the one' brakes) would start getting into a habit of going to the bars and needing a bleed.
1) Did you bleed them as regularly as any DOT brake needs bleeding to prevent the fluid from getting old and the brakes feeling "spongy"?
2) Also, did you have the mastercylinder piston replaced in the oro/TheOne MY09? That would have likely solved that issue of the lever pulling in towards the handle bars - some had the issue that a small groove developed over time in one of the mastercylinderpiston seals allowing fluid bypass causing the issue you've mentioned which can easily be repaired, possibly even under warranty.
