bear the bear
Is a real bear
Watch from 0:58 on
Then the follow up to how much pressure to explode a wheel
It's also dependent on the tire size, so two factors at work.Depends on the wheel. Stans have a pretty low recommended pressure. Easy to blow a tyre off above 50psi. Better than destroying a rim I guess.
It’s rare I go below 30psiI get scared going above 30psi! Never had to go above 40 and usually only 30-35 to seat the tyre.
Maxxis/Conti tyres on Spank 350s or EX511s.It’s rare I go below 30psi
What rims?
my DJ bike I whack 60 out back, 55ish front. Mavic 729’s. I’ve had some big cases and hyucks to flat too.
rocked up to check out a polygon xx/trail bike last night, 80psi in the tyres—i push on the fork, won’t move ahhh it has a remote lockout on the bars, i click it..still no movement, frig i have just locked them,..must have been over 150psi, puts my finger on the valve for 5 secs, forks spring to life—-french canadian says what you doing, i say the those 2 shiny metal tubes in front supposed to move ups/down—i ask him how many rides you do? 2 he says 1 yarra trail then 1 xc race, scared him he packed up bike then didn’t touch nine months, wasn’t for me he said, not for anyone running those pressures i says backalthough anyone who runs 60psi in anything fatter than 30mm wide tyre needs a kick in the head.....
I'm more impressed by the tire pump than the two hardcore roadies destroying stuff!Watch from 0:58 on
Stans with maxxis. Wouldn’t know what a tyre seating/fitting issue was...some tyre & rim combinations across all cycling disciplines that are just pains in the arse to seat. Far AM/ "Endooro" tyres & rims are frequently among the least co-operative
