V brake mount studs - removed
Mtb1speed
Hey guys - need help/ideas. I've got a Apollo carbon frame with v brakes. I'm putting discs on (yes it has tabs also). When I remove the posts it naturally leaves two threaded holes. This is where I need help. Where can I get some rubber grommets/plugs to fill them?
Minlak
custom titis
Windscreen silicon fill up the holes neatly and boom tish magic grommets ... if ever need to use again pointy pliers will pull out the silicon likkity split...
Plankosaurus
Spongeplank Dalepantski
i had some in a frame once so yeah, they're around. i'd say just go ask a couple of bike shops, surely they'd be able to give you something...
Mtb1speed
Damn I hadnt even though of the windscreen silicone, it would even be shiny a little.
Have been to a couple of LBSs in Canberra and pretty much all declare it an odd ball item and IF they were available they say they wouldn't stock anyway.
Minlak
custom titis
drop into bunnings there will be 50 different types of silicones for around $10 a tube or less choose 1 you like and squish away
steve24
I beleive the holes are 10mm x 1mm pitch which is not a common thread. Rotor bols are 5mm....
flamin'trek
Take old mounting posts to bolt suppies shop. get same threaded bolts? I just got some M10 (i think) bolts with allen key head for the same purpose. The bolt shop had a sample board, I just screwed the posts into the sample board and read the size - easy.
tomacropod
You can get a kit that has a plug for the right hand hole and a hose guide for the left hand hole. I believe a shop in Dickson has some old stock of this item.
- Joel
Mtb1speed
- Joel
Thanks Joel - I'll check with MA and see what they have. Haven't been in there of late, but trust them (which is a good thing) to have some of the odd ball stuff.
