these are the tools you need. you could also use threaded rod to install and a socket/extension to remove BBs. be very careful to 1. get them in (BBs) squarely and 2. don't over tighten, otherwise outer edge on BB shimano will crack.Thanks for the quick replies. One more question, what tools would I need to remove the old bottom bracket and install the new one?
Looks good. Reasonably priced too. But sold out.these are the tools you need. you could also use threaded rod to install and a socket/extension to remove BBs. be very careful to 1. get them in (BBs) squarely and 2. don't over tighten, otherwise outer edge on BB shimano will crack.
you could also consider using some (Loctite ® 609™ Retaining Compound),to seat bearings in BB shell area. not to lock them in but to keep them firmly in place to avoid creaking.
not a bad price: AU$49.00
Fixed for you.one day someone will invent a BB system that screws in AND DOESNT CREAK!!!!! hang on it's already been done, wft. ;-)
More fixing.Correct. BB 91 is the same but the XTR version. Probably 2 grams lighter AND $400.00 MORE EXPENSIVE.
