my_bike
You can buy HCl (hydrochloric acid) from bunnings.Probably harder to get and wont work.
Putting a strong acid like HCl onto bare steel and aluminium probably isn't the best idea.You can buy HCL (hydrochloric acid) from bunnings.
I know as it eats away at most weak metals as Magnesium and probably would eat at Aluminum too. The HCl at Bunnings is not the strong stuff so it's the tiny bit safer.Putting a strong acid like HCl onto bare steel and aluminium probably isn't the best idea.
Now you're getting somewhere... probably something like thisI have been looking up the chemistry for the Ammonium-Aluminium reaction and I haven't come across anything conclusive....
Edit: It may just be the Aluminium Oxide or Aluminium Hydroxide is soluble in Ammonia solutions.
I'd rather handle concentrated Ammonia solutions than hot concentrated Caustic solutions any day of the week.Mix yourself up a saturated solution (slowely in a glass or ss vessel, not plastic).
Heat this solution up to about 70 degrees (so hot water temp). Be especially careful here.
I work with both NaOH and KOH caustic solutions as well as liquid ammonia refrigerant.I'd rather handle concentrated Ammonia solutions than hot concentrated Caustic solutions any day of the week.
Definitely, but despite what he asked for he doesn't need Liquid Ammonia, he needs an ammonia solution which is the sort of stuff your mum uses to wash the floor.I work with both NaOH and KOH caustic solutions as well as liquid ammonia refrigerant.
Kinda hard to compare the two, but I'd prefer the Caustic solutions.
Maybe also some life/disability insurance.Heat this solution up to about 70 degrees (so hot water temp). Be especially careful here, I recommend chemical gloves, a face shield and an acid vapor mask.
As alchemist said above, we're talking about solutions of Ammonia, a very different beast to liquid Ammonia. Whenever people discuss chemicals, especially discussions between those that work with chemicals and those that don't, nomenclature is always an issue.I work with both NaOH and KOH caustic solutions as well as liquid ammonia refrigerant.
My solution will work. I've worked with hot caustic for plenty of things and you take precautions to mitigate the risk. If your retarded, then sure don't do it, but a bucket of saturated bi-carb solution will pretty well solve all your problems.The suggestion to use hot caustic is a good example of why you shouldn't take any advice you get on the internet.
Yes but considering the concentrations people are banding about, once the reaction is underway the heat will liberate NH3 gas. It's worth keeping byproducts in mind as I've seen more than one evacuation as a result of people forgetting stuff they should have learnt in year 9 chemistry.Definitely, but despite what he asked for he doesn't need Liquid Ammonia, he needs an ammonia solution which is the sort of stuff your mum uses to wash the floor.
I work in the engineering department of frozen meal facility. Caustic is used for the washing areas and for waste stream pH correction. We use NH3 as the primary refrigerant in our fridge plant.As alchemist said above, we're talking about solutions of Ammonia, a very different beast to liquid Ammonia. Whenever people discuss chemicals, especially discussions between those that work with chemicals and those that don't, nomenclature is always an issue.
Out of interest Toodles, whats your line of work?
