mty10@
go home,ho bout sum maxxxxxxis minions?!?!?!
tey gt gud grip and lst fo soo lung
by sum
onley lyk 60 $$
weit lyk nly 1500 kg'z
get a life,
stop being a penis.
YOA. UNDERSTANDA. MEA?
by sum
onley lyk 60 $$
So how's your scooter going?ho bout sum maxxxxxxis minions?!?!?!
by sum
onley lyk 60 $$
Were you running the 2.1 or 2.25?Tyre: Racing Ralph (as a front)
Strength: Fast rolling , Hooks up well in loose corners, better than the Larsen
Weakness: none so far...very very impressed
Bottom line:Fantastic
RR is a 2.1 - just back from a blast round out local track - 8.5km that includes sand chutes, off camber grass and sand, clay berms and the likes...usually club racing averages around 22-26min a lap...best combo I found so for for this type of thing...heaps of grip from the Larsen up the short sharp climps and the RR holds on well round the off camber loose stuff at speed...if only my fitness was as easy to come byWere you running the 2.1 or 2.25?
I have been using 2.1's on my HT for about 700km and they have been fantastic so far although the rear is looking a bit tatty now.
I am thinking of putting a 2.25 up front to see how it performs.
Tyre:Continental Race King Protection
Strength: Fast rolling , Grippy , Light
Weakness: FAAAST wearing, KNobs being ripped off.
Weight:580 in 2.0
Bottom line: Did not last long. However this is to be expected with all light soft compound xc race tires. The biggest issue was the knobs being ripped off.These are light fast and have good grip ( considering).
Tyre:Continental Race King Wire Bead
Strength: Cheap (Payed 21 from crc) , Fast rolling , Corners Pretty well (in dry)
Weakness: Side walls ruined after 100km. Had to throw them out due to cuts.
Weight: 530g (2.0) or 480g (2.2)
Bottom line:Cheap alternative to the more expensive versoins. I may have been unlucky with the sidewall who knows?
Tyre:Continental Race King Supersonic
Weakness: None so far. Have outlasted both other race kings. ( However it was run up front )
Weight:liiight......530ish?
Bottom line: Still going strong after a few races, a 24hr and training. Good tyre they are verry light i have not had any problems with wash outs and the like.
I wouldn't advise that - have used the 2.0 RK (F&R) and they are much poorer than the 2.2 size. I did a lot of reading after that little experiment and seems that is the common consensus. I then put a 2.2 RK on the front (and after getting it the right way round) and it gives much better traction and control than the 2.0 RK.Might have to resort to a 2.0" for the rear in future -- if only the Race King came in a 2.1"!
Maybe OK for the rear but I did not like them in that size at all.
Great post. Hummm, to Aspen or Monorail, that is the question. The monrail seems to have a bit more in the centre than the Aspen, so might give it a crack. On the other hand I might just stand in the LBS and toss a coin as I wouldn't mind trying the Aspen. Ah the choices!I am using the 2.1 Aspen exception on the front at the moment, and i like it. It is great for hardpack (side knobs dont fold like the crossmark) and shallow loose stuff.
The volume is much wider and taller than a "2.1" racing ralph, although the profile is rounder so it doesnt have the same authority in loose stuff. Measures 52mm wide at 40psi on an XC717 rim, vs 49.5mm for RR. Very fast rolling in the exception casing, feels faster than a 2.1 RR, maybe due to larger rolling diameter.
It's essentially a race tire, and is deffinitely not skittish at 30psi. Probably look elsewhere for a true do-all trail tire (maybe try the 2.25?). Havent had any wet weather to try it in, although looks like it will clear mud ok with the open design. I may not every buy a different summer tire again...
Interesting how you go with this - anyone else use larsens on the front? I've recently switched to larsen front and back, seems ok so far (after a few days). I think I'll go Ignitor on front and Larsen on rear - or a maxxis dy-no-mite on the front - do they still make the dy-no-mite?Just about to try a Larsen on the front, which feels a bit small in 2.0 but we'll see...
