marc.r
Hi
Just wondering if anyone has had any experiance with there type 2 rear derailleur getting stuck and losing chain tension at all. If I am in the biggest or second biggest gear and the rear suspension compresses the derailer mores forward and gets stuck this leads to dropping the chain. Im thinking it must be some kind of clutch issue. The derailleur is quite new and this was not the case when first installed.
I added a couple of photos for reference
Any help would be great
if done that with an x7 as they got some plastic on the back that can tear if you get a stick in it pulling the mech all the way forward. have a really close look and see if one of the stopper bolts has pulled through some of the plastic at the back of the mech. im not saying this is the case but my dads mech looked exactly like that and I couldnt work out why until i looked really close.
if this is the case use a bit of english and pull the cage back through the plastic and it will continue working fine but obviously whenever the cage get pulled all the way forward again it may pull back through the plastic since a channel will now have been carved out. if this happens just fix it again. if it happens all the time and frustrates you buy a x9 mech as its strooooonger!
hope this helps!
