Huh?? mine climbs the steep hills at manly dam fine without having to put too much weight onthe front, and I'm running a shorter stem. In fact it climbs better than my old GT avalanche hardtail did. The maestro suspension is awesome for keeping traction up hill as wellits not too bad its mostly the geometery which is more of an issue with climbing as you really have to put urself up front to avoid the front tipping up as its an all mountain geometery bike.
Its fine though for going up hill as long as u r dedicated.
Mate, sounds like you're enjoying the Reign heaps! I own a 2008 Reign 1 and what you said about the front wheel lifting when climbing is true. The front end is ridiculously light and you really have to crouch over the front while sitting down to keep it all on the ground. But the light front end also helps with clearing obstacles on the way up, lift the front over, and the rear just keeps tracking.
My mate Jing also bought a Reign (Reign 0) and this was his first time out on it, you can see the front wheel lifting in this shot. It's what happens on the Reign on a climb if you ride it like your fave hardtail, but you get used to how you should climb on it pretty quickly.
Unfortunately this is common on long travel bikes. It's very hard to keep the body weight over the front when it is naturally high. You can try hard- but then you loose traction at the back.Mate, sounds like you're enjoying the Reign heaps! I own a 2008 Reign 1 and what you said about the front wheel lifting when climbing is true. The front end is ridiculously light and you really have to crouch over the front while sitting down to keep it all on the ground. But the light front end also helps with clearing obstacles on the way up, lift the front over, and the rear just keeps tracking.
Great to hear but I shudder at your superannuation...and your mortgage.Looks great justin,love the giants,love the de-sticker,have you already got the upgraditis bug happening? Myself at 42,the bug has bit and bitten hard,just throw money at the bike without a care in the world!
I got it for an absolute steal at $1800 from Cranks on a runout sale. I knew I was lucky about the price then but handing over $1800 for a bicycle was killing me at the time, but I really realise how lucky I am now.looks the goods mate how much did that set you back
LOL I'm so happy to hear that. Well, the modifying bug really hit hard on the single speed I built up (check my sig.) but the Reign has been more about getting the riding bug. I push myself harder every time I go out there on it, it's a beast of a bike, confidence inspiring. I love it. I AM tempted though for sure to get the weight down some. Every time I take it out I realise it could do with some extra things, after yesterday's ride through the Dam (see pics below) I realised that it needed:Looks great justin,love the giants,love the de-sticker,have you already got the upgraditis bug happening? Myself at 42,the bug has bit and bitten hard,just throw money at the bike without a care in the world!
oooooh the modding has started- red "bits" is always the first step to "upgradeitis"Yesterday I mucked around with the set-up some more. I felt stretched out a little on Sunday so I've made some adjustments. I realised the low riser bar was mounted pointing forward quite a bit. This made the bar about 40mm further away from me to the front and about 30mm higher too. I've now adjusted it back towards me some more, re-adjusted the brakes/shifter and everything feels a little better but I'll have to test it out on a trail soon to be sure. I've also noticed the stem's got a pretty big angle on it, and I'm tempted to try a shorter stem with less rise.
With adjusted cockpit, you can see the difference between this picture and the one in a couple of posts above.
I also just whacked on some gear I had lying around from my single speed build. Namely some red KCNC ring bolts and alloy water bottle bolts. All lighter and as strong as the stock items, so no harm done.
I also had a KCNC jockey wheel (only one though lol) from the single speed's tensioner which I am no longer using so on it goes.
