The placement of the rear axle in relation to the rear wheel determines the whether the suspension is FSR or a single pivot. The Kona Operator has the rear axle placement on the chain stays which is then connected directly to the mainframe. The seat stays and rocker linkage of the Kona Operator only serve to control the compression of the shock. It may be a four bar linkage, but it is still in effect a single pivot. The Norco Aurum has the rear axel connected to the seat stays, and is not directly connected to the mainframe.
Linkage Activated Single Pivot: (rear axle on chain stays)
FSR/Horst Link Suspension: (rear axle on seat stays)
7350 is around 6600 AUS currently.The top of the range model is $9500 CAD! Hopefully (but not likely) we get prices similar to the US where the bike has a listed price of $7350 USD - which for the spec would be a pretty good price in Oz.
Apart from the fact that it's completely different, in nearly every way, it is quite similar -.-Not overly impressed. Looks like a slightly modified Glory. Just sayin
The answers you seek lie in the thread you didn't just read.umm, ok so I couldn't really be bothered reading the whole thread, but I did notice a lot of people a saying they look like treks, which I'll admit, they kind of do...
So anyway, would people rather the trek or the norco ??? I've always liked Norco DH bikes, no matter what anyone says about them, and this one just looks even better than previous models... spec seems a bit higher to the trek too, and similar price range, maybe a slightly better build??? definately better colour scheme...
what are other peoples thoughts ???
More effort required. C-
Both very similar in terms of spec and weight. Have owned the previous 2010 and 2011 glorys and they ride great. In the same position as you at the moment tossing up between 2012 glory0 or aurum1 or whatever else, havent ridden the new aurum though. I'd prefer the codes on the glory to the elixers on the aurum, however on the glory ive destroyed those dt ex500 rims before without much effort as have many others that ive seen on rotorburn. Not sure about running the 240 hubs either on the glory either as they are intended as a bit lighter xc hub. I cant speak for the sun wheelset on the aurum as i havent used it before but the rim is a similar weight to the dt ex500 (sun inferno29 is only 20g heavier and is therefore probably also an enduro rim like the DT rather than a DH rim). You would be fine with either based on the price you can get one for, but if you are riding a lot of rough tracks or are hard on your bikes then maybe think about a more heavy duty wheelset on whichever one you go for.I am bringing this thread back from the dead (sorry?) -
For someone new to DH specs, does anyone have thoughts on the comparison between the Glory 0 and the Aurum 1 (same retail cost). I guess I am looking for the pros and cons of each assuming the same price.
***Aurum***
fork Rockshox Boxxer R2C2 CL 200 mm
rear shock Rockshox Vivid Coil R2C
grips Norco lock on grips
handlebar Easton Havoc DH bar 760 mm
stem Easton Havoc bolt on direct mount
seat post Norco Lite two bolt seattpost
saddle WTB Silverado Race SL
Brakes Avid Elixer 9 disc brake with 200 mm rotor
Shifter Sram X 9 rear 10 speed shifter
Derailleur SRAM XO DH short cage
Cassette Sram PG-1070 Cassette 10 speed 11-28T
Chain Sram PC 1051 10 speed chain
Crank set Truvativ Decendant DH single 36T 83 mm shell
Chain Guide E-13 LG 1 chainguide with Taco
Pedals Black Spire low profile flat pedal
Hubs Sun Jumping Flea , 20 mm Front and 12x157 Rear
rims Sun Inferno 29 welded rim
tires Maxxis Minion DHF 26 x 2.50
***Glory***
Frame ALUXX SL FluidFormed™ alloy Maestro 8” travel
Fork RockShox Boxxer R2C2 w/20mm Maxle DH 8”/203mm
Shock RockShox Vivid R2C
Handlebar Giant Contact oversize alloy 750mm x 19mm rise
Grips Giant lock-on
Stem Giant Contact DH oversize alloy, direct mount, 40-55mm adj. extension
Seat Post Giant Contact oversize alloy micro-adjust 30.9
Saddle Fi’zi:k Tundra w/K:ium rail
Shifters SRAM X-0 trigger shift 10 sp
Front Derailleur NA
Rear Derailleur SRAM X-0 10 sp
Brakes AVID Code hydraulic w/8” front & 7” rear rotors
Brake Levers AVID Code 7 hydraulic
Cassette SRAM PG1070 10 sp 11-26T
Chain SRAM PC1071 10 sp
Crankset Truvativ Descendant 36T
Bottom Bracket SRAM GXP integrated, outboard
Shift/Chain Guide MRP G2 Mini SL
Rims DT Swiss EX500 disc 26” x 32H w/eyelets
Hubs DT Swiss 240s: 20mm front, 12x150mm rear#
Spokes DT Competition 14/15G butted stainless w/alloy nipples
Tyres Schwalbe Muddy Mary, EVO DH, 26x2.5
Other Giant alloy 12x150mm rear through axle
In relation to this link, have a look down the page at the Revolver 29er. For what its worth, I reckon this bike portrays what I think of 29ers; they look stupid and ridiculous and belong on the road, not on a mountain bike trail.
