fatboyonabike
Captain oblivious
not a good idea
to do any sort of electrical work you need a nice clean constant current draw.
Batteries do not behave in a linear way, rather when you use a battery and draw voltage down from the battery, to do the same amount of electrical work from a lower supply voltage the current will increase, this will either fuck your inverter or draw down the battery very quickly.
running off a gen is probably a better bet, but bear in mind that the microwave will cause issues if the Kva is not sized correctly, the coffee machine is not a issue as it is a purely resistive load, but as the microwave magnetron comes on and off it will cause short loading issues for the gen and possibly stall it
