Glycol usually finds the minor leaks and turns them into big ones.Nope, that’s a new one... Doesnt sound like a thing to me, but happy to be educated - I’ll dust of my chemistry text books.
Why? Cause it’s high viscosity, runs higher temps, or some chemical reaction?Glycol usually finds the minor leaks and turns them into big ones.
If you’ve got those sort of leaks I’d warrant you’re in for bigger problems anyway... Nope, never heard of that, always changed the coolant on a new acquisition if I don’t know the history.Glycol usually finds the minor leaks and turns them into big ones.
You usually don't find them until you pressure test the system as a lot cars don't go to full pressure unless the car is run in abnormal conditions. If I find a car with off coloured coolant or rusty water and asked to flush the cooling system I usually pressure test it before, check the condition of the hoses and check the weep holes on the water pump and if I see any minor leaks I recommend them repaired but most shops these days just throw the coolant flush machine on there and a few days later the car comes back with leaks everywhere.If you’ve got those sort of leaks I’d warrant you’re in for bigger problems anyway... Nope, never heard of that, always changed the coolant on a new acquisition if I don’t know the history.
I don't know what chemistry is behind it but that's what happens, if you change the coolant as per recommendations you'll never have a problem, water pumps last longer, no sludge build up in the radiator and if you buy a car that's not maintained it's just that.Why? Cause it’s high viscosity, runs higher temps, or some chemical reaction?
I’d change all fluids on a newly purchased sub $5k vehicle. If it’s got a drama then I’d rather know now than 100km from home.
Yeah fair enough. If the coolant is rusty, that dissolved metal had to come from somewhere! I’d be shying away from buying a used car that clearly neglected though...You usually don't find them until you pressure test the system as a lot cars don't go to full pressure unless the car is run in abnormal conditions. If I find a car with rusty water and asked to flush the cooling system I usually pressure test it before, check the condition of the hoses and check the weep holes on the water pump and I see any minor leaks I recommend them repaired but most shops these days just throw the coolant flush machine on there and a few days later the car comes back with leaks everywhere.
This is the common scenario that I've seen working in workshops, Immaculate car, good service history with sale price of $10000, exact same car with no history of maintenance $9000, you can guess 9/10 which car they go home with and it's not the good one.Yeah fair enough. If the coolant is rusty, that dissolved metal had to come from somewhere! I’d be shying away from buying a used car that clearly neglected though...
Have you seen his dog? You'd need a full length sunroof in a wagon for Burt to stand up. Especially in a wagon the size that you'd be recommending.......Ok, I’m still missing something. Why again would you buy a 4WD for passenger car use and towing small trailer?. (my 900cc three cylinder Clio towed a box trailer comfortably). And it’s hefty on fuel sucking down over 10l/100. I just don’t get the suv thing, why is heavier thirstier unweildier better than a station wagon?
Is it just marketing? Because by pulling out a tape measure I don’t see how the “it has space” argument is a thing.
I felt the same way until I looked at what was available second hand (especially in manual). There isn't much to choose from that is reliable, easy to get parts and doesnt hold it's value (so is cheap to buy). I ended up with a 2006 xtrail because it was the sensible decision, but I would have chosen something else if I went new.Ok, I’m still missing something. Why again would you buy a 4WD for passenger car use and towing small trailer?. (my 900cc three cylinder Clio towed a box trailer comfortably). And it’s hefty on fuel sucking down over 10l/100. I just don’t get the suv thing, why is heavier thirstier unweildier better than a station wagon?
I recently bought a rav. I tried really hard to buy a wagon and a 'small car' was too small for my needs - it's usually the baby seat test that forces you to upgrade to a bigger car - you can't fit squat in a rear facing configuration.Ok, I’m still missing something. Why again would you buy a 4WD for passenger car use and towing small trailer?
Marketing for the masses, the rest of us get stuck with what the masses buy. Basically if you are not the type to trade in a car every 3-4 years then car makers don't give a squat about you. I was willing to gamble on reliability and parts support but the ZB commo is considerably longer and bigger car. With a hitch rack on, it doesn't actually fit in my garage!So it’s marketing then... Annoying. I’d take a Commode wagon over an suv, surely that’s got the space and towing.
How bad’s your driving ability if you need an amazing handling car to corner at the speed limit?So it’s marketing then... Annoying. I’d take a Commode wagon over an suv, surely that’s got the space and towing. Reliability hit worth it to avoid driving a truck?
I dunno, but when a kid or a dog runs out or I need to take evasive actions on a high speed country highway, I’ll take every last bit of handling prowess I can get my hands on and hope I never need it.How bad’s your driving ability if you need an amazing handling car to corner at the speed limit?
Drive an actual truck then drive an suv and get back to us on what handles like shit.
That and the fact modern cars with all the electronic wizardry means most people never know what dynamics are and never learn about recovering a slide or anything. And the vehicle hides its limits and at anything under the limit they’re benign.Because 'Kids' these days aren't taught vehicle dynamics, they're taught how to park. Which includes me, I learnt what I know from late night jaunts. So they buy what is cool and trendy, leaving us who know what 2 tons of out of control vehicle can damage to make do with what they discard.
I'll be in my rocking chair if you need me.
Kid's aren't even taught basic skills like emergency braking. It's sad. Most of me and my mates learned the ropes late night hooning. Yeah the stuff was sometimes dangerous, but it did make us better drivers now.Because 'Kids' these days aren't taught vehicle dynamics
Yep - just hit the roo, and don’t risk hitting the tree.Kid's aren't even taught basic skills like emergency braking. It's sad. Most of me and my mates learned the ropes late night hooning. Yeah the stuff was sometimes dangerous, but it did make us better drivers now.
On highway swerving, I never swerve at high speed -that's how you die. Safer to hard brake and risk a collision. Of course the correct method is to hard brake and swerve last minute but teaching skills like that to average joe is a recipe for disaster.
