^ this. For cleaning brakes I find the stuff which cleans the things that stop 1500kgs of metal work fine on the things that stop 110-odd kgs of me+bike.Easiest stuff to get is brake cleaner in a can- any auto shop will sell for $10 a can and is made for the job - it's all volatile and evaporates completely . Also because it's pressurised it does a better job than alcohol on pads.
Brought to you by Brazzers...Impregnated ( love that word ! )
FFS don't use it on anything with rubber! Or paint! Or plastic! Or glue! It's a great product for dissolving shit but...isopropyl is saferAcetone is easy to find at hardware and paint shops. 1 small bottle lasts for ages. It's the same as brake cleaner you get in spray cans or polly pipe cleaner without the red dye.
Completely wrong (except for the PVC pipe prep bit) wrt commercial brake cleaner formulation!!!Acetone is easy to find at hardware and paint shops. 1 small bottle lasts for ages. It's the same as brake cleaner you get in spray cans or polly pipe cleaner without the red dye.
The reason I went with acetone was because when my can of spray on brake cleaner ran out I looked at the active ingredient. Acetone. Some products still use it. Behold: http://www.bluechemgb.com/products/powermaxx/brake-cleaner-spray-with-acetone-600ml.htmlCompletely wrong (except for the PVC pipe prep bit) wrt commercial brake cleaner formulation!!!
None of them use acetone for the reason Chops gave.
They are mixtures with any or all of: alcohol, benzene, low boiling point alkanes (typically hexane), tetrachloroethylene.
eg. http://www.crcindustries.com/faxdocs/msds/5089.pdf
As has been noted, these solvent mixtures are more effective overall for brake cleaning than just a single component solvent like alcohol. Especially for mineral oil and grease.
Lucky disc rotors aren't made of rubber, plastic, covered in paint or glued on. You left out not drinking the stuff. That'd be bad to.FFS don't use it on anything with rubber! Or paint! Or plastic! Or glue! It's a great product for dissolving shit but...isopropyl is safer
I'd add to that the CRC brakeclean is the best product for brake cleaning in an aerosol can available. Some of the other cheaper/no-name products have additives that make them less effective. Brakeclean will dissolve any oils that you don't want on your brakes and wash them off. Its important to spray enough that there is lots running off. If you just spray a little, it will dissolve the oils but when it evaporates, it will leave them behind. Liberal application is what is required....As has been noted, these solvent mixtures are more effective overall for brake cleaning than just a single component solvent like alcohol. Especially for mineral oil and grease.
You missed the point, people spray isopropyl on brake rotors and use it for cleaning other bike parts...and those bits have paint, rubber, plastic, glue...Lucky disc rotors aren't made of rubber, plastic, covered in paint or glued on. You left out not drinking the stuff. That'd be bad to.
However, the rubber seals on the calipers/wheel bearing would be at risk using it in the manner brake cleaners typically are used.Lucky disc rotors aren't made of rubber, plastic, covered in paint or glued on. You left out not drinking the stuff. That'd be bad to.
