swaz
Completely wrong (except for the PVC pipe prep bit) wrt commercial brake cleaner formulation!!!
None of them use acetone for the reason Chops gave.
They are mixtures with any or all of: alcohol, benzene, low boiling point alkanes (typically hexane), tetrachloroethylene.
eg. http://www.crcindustries.com/faxdocs/msds/5089.pdf
As has been noted, these solvent mixtures are more effective overall for brake cleaning than just a single component solvent like alcohol. Especially for mineral oil and grease.
You sound like you know your stuff. Riddle me this if you can please.
How exactly do these 'cleaners' aka solvents work if just spraying on a surface without any manual wiping to remove the dissolved oil? Do they break down the oils into a different substance that can then vaporize? Or do they just act like other solvents and bring the oil into suspension to they can be wiped/washed off.
