I think that was your problem. The water in your old dot fluid caused corrosion.Eek, ok.
They felt perfect, shouldn't have opened the fucker up.
Blockage is probably very close to the bleed nipple. Regardless, I would do a complete disassemble and inspection. If you get flakes of corrosion near the piston seals they could blow out at a very bad time.I think you may be right about the corrosion, there's a white substance on the rubber seal for the reservoir which may relate to that?
You can see the colour of the fluid in the reservoir, which is pretty similar to what came out the other end.
I took the bleed nipple off completely, and squeezing the lever pushed nothing at all out of the bleed port (nipple back on in the photo)
But, bizarrely, I put it all back together and the brakes work just as they did before.
Not sure what to make of this now, and what i should do about it.
I use shimano's which are in beatable if properly bled, once a year..
Hopes are for fashion victims who spend more time polishing them.
Not sure about other brakes..
I'm not sure a lot of people are ready for that kind of commitment.Until a seal starts leaking then have to throw the lever or caliper out because they don't sell spares. Hopes are literally for life because you can buy every small part and fully rebuild at home.
What if you want to squeeze other brakes?
Why do we have to settle so early?
Really, Hope are coming across as a little clingy, and not the free spirited kind of brake that I need and want in my life right now.
I also prefer brakes that use mineral oil as it doesn't nark your paint up.
After reading this thread and all the talk of Maydena being crazy steep and hard on brakes, I've decided mine definitely need to bleed before I get down there.
My question is on bleed kits do I need to shell out on a genuine Sram kit for my Avid DB3's or are the kits on eBay decent enough. I've also seen the kits from epic bleed solutions which look decent, any advice appreciated.
Sent from my MotoG3 using Tapatalk
I thought this may be the case with the brakes. I've had no dramas with them at Derby with 180 rotors and sintered pads, but Maydena looks like a whole different level and good brakes sound like a must. Might be time for an upgrade.Average Ebay kit is good enough usually, but wash everything in the kit after use, prolonged exposure to DOT fluid will destroy everything .
Bigger concern are the DB3 brakes. These are effectively Elixirs, twin piston calipers. You're going to quickly be out of brakes with these. Metallic pads and 200mm rotors would be a must for anything gravity, as these are really an XC/trail brake at best.
2015 Nukeproof Mega AM 160 travel front and rear.What bike do you have them on?
