Product Review Brand X Ascend II dropper post and remote
What’s the one thing that turns a good bike into a great bike? It’s the one item on trail and enduro bikes now that is so common that it’d be strange to see a bike without one. I totally hate the saying “game changer” but yep, dropper post’s have changed the way we play this game. There’s so many to choose from nowadays that it can almost put a new buyer off spending that much money for something they haven’t used. Make no mistake, a top of the line dropper post is a real pleasure to have underneath you but can you achieve the same result with your riding from something bought on a budget? Yes, yes you can. Read on to check out the Brand-X Ascend II dropper seat post with the Brand-X Ascend lever kit V2.
351959
Item: Brand-X Ascend II dropper seat post with the Brand-X Ascend lever kit V2.
Purchased from: Chain Reaction Cycles (Post and lever)
Purchase price: $167.99 for the Ascend dropper post and $74.99 Ascend lever kit
351960
I’ve tested, trialed, reviewed and purchased a lot of dropper posts and am a self confessed addict; I love what dropper post’s do for mountain biking. They aren’t a complicated addition to a bike and can be maintained quite easily. The range is huge and each promises to do something better than the next. Like anything, you can spend big bucks on supposed high end gear and thankfully you can achieve the same on-bike experience of a dropper post by spending a little less. I set out to upgrade a dual suspension bike in my stable that is comparatively outdated now being a 2015 model frame. Crazy huh! The tech that was “in” in 2015 is now talked about as old school. I wanted to modernise this particular bike and the first step was a dropper post but wanted to do so at a lesser cost than what I have spent on other vessels. The problems I faced when choosing a post were an alloy frame with heavily butted tubing, lots of curves and the idea of drilling holes to run a stealth dropper wasn’t appealing. This narrowed my search to something that had to be externally routed, 30.9mm clamp and not too long that it wouldn’t slide into the frame appropriately. To my liking, the Brand X Ascend ticked every box for this project and that was before I looked at the price, under $200? Yep, $168 gets you in the game.
The Brand X post is such a simple fit too. Being an external cable, you only need to slide the post into the frame, bolt the remote lever to your bars and double check the cable length. The bulk head of the cable sits snug underneath a well sealed rubber cap on the post and is routed along your frame to the remote lever where it is tightened with a firm fit to the lever body. The Brand X Ascend lever is a perfect match with the trigger point of the lever sitting under your bars; in my case on the left hand side. There’s a simple barrel adjuster on the remote body to get the feel you need and take out any slack from the cable. And to make the whole setup even more hassle free, the Ascend lever kit is a hinged clamp so you can fit it to the bars without needing take your grips and brake levers off. You know what? The length of time it’s taken to read this is about how long it takes to have your Brand X dropper fitted, it’s that easy!
351962
Now let’s get to the point. This post and lever setup is pretty cheap when compared to a set up that can be upwards of $600. I own those posts and they’re bolted to bikes that are ridden on trails that your Mum chews her fingernails over. The bike I’ve grabbed the Brand X dropper for isn’t being entered in round 3 of the Enduro World Series, it’s a trail bike ridden on medium grade trails and primarily XC style laps. The post needs to stay up & firm and be reliably out of the way for the fun bits without slapping your backside and launching you over the bars. I’m happy to say that it achieves that without fail and in the months I’ve been studying this post, it hasn’t varied in feel from the day it was installed.
The lever action is a positive cable pull and exact response from the post on the drop and on the return. The return speed doesn’t stamp the brand of your saddle into your butt cheek, it’s a direct predictable motion. It does feel light to touch though, meaning you don’t punch it in angst to get it moving and doesn’t have that “I’m about to break my lever” feel. Not to harp too much on comparing it to other posts but it is a softer touch to the lever to activate the drop and return so my advice is not to cover the lever with your finger as it is that responsive that it will activate the mechanism.
351961
I’ve had a gripe in my time with seat clamps that need to be tightened so much to avoid that dreaded saddle creak that it near snaps your allen key doing so. The saddle clamp on the Brand X has the same tight fit under your saddle as you’d be used to with any other post but so far, no creaking! I have been known to lightly grease saddle rails to avoid some creaks and do nasty things to seat clamp bolts but this is straight forward with no fuss.
The post I have fitted to the bike is a 125mm drop alloy dropper post. It’s slid into a 30.9mm frame and clamped up with a quick release seat post clamp. This isn’t super common as you can’t get an exact number on what clamp tension you should have but follow your nose and you’re just fine. The post in full is 400mm long and weighs 600 grams without the lever and cable attached. It’s sold new with a 2 year warranty and is part of the Brand X dropper post range with varying clamp sizes and longer post drop options with internal and external routing available. Not many (if any) other brands offer both cable routing options so it’s nice to see a well priced and well functioning dropper aimed at almost every kind of bike.
351963
To paint the simple picture, the ideal market that would suit the Brand X Ascend dropper post is those looking to get a great feeling dropper post on their bike without the expensive price tag. By all accounts during my review process, this post has been just as capable as rival posts and hasn’t developed any slop or knocks that make it feel under engineered. In my last dropper post review I had refrained from saying that I wonder why some dropper posts are so expensive when this one kicks butt for less money. I’m definitely echoing those thoughts with this post and at almost a third of the price, why wouldn’t you look at the Brand X Ascend?
As this is part of an upgrade path on this particular bike, stay tuned for more!
351964
You’re not always right, but you are on this one. Running a couple for quite a while now. Have been faultless.
My experience is it has performed without a hitch over the last three months. There is a bit of play but about the same as my KS Lev.
It has just started getting a little slower in it's return and I was thinking of taking it apart to re-grease, found this vid for the PNW cascade, these two posts look uncannily similar anyone know of any other resources for this post?
PNW-Cascade service
Yep I got one for my brothers bike. Has been perfect. Can't see any reason to go more than double the price for a different brand.
Anyone know if you can rebuild the cart on these droppers or cost to buy a replacement ? The problem with most droppers is when the cart fails, by the time you buy everything you need to replace it, it's almost the price of replacing the dropper.
PNW-Cascade service
They are the same as the Raceface Aeffect dropper, which means they are fully serviceable. See teardown here https://nsmb.com/articles/race-face-aeffect-dropper-post-teardown/
I've been using one for over 12 months and it's been faultless. To be honest its my favourite low to medium cost dropper posts ie Manic, Oneup and Lev.
-It's rebuildable.
-Very reliable and has a very solid saddle mechanism that doesn't squeak.
-Has a very light actuation that relies on the cable inner, unlike the Oneup.
-Not much bushing slop.
It's not until you get to Fox Transfers, Bikeyoke Revives or DVO Garnets that you begin to see a real difference in the quality of operation.
So Dozer obviously spent the extra for the under the bar lever, how is the standard lever that ships with the post for those that are using it?
A little cheap feeling, and fiddly to mount, but works better than the standard KS one.
They must've changed the package contents, when I bought one in December it came with the under bar lever (but not the 2X lever). Was insane value at $167.
My Brand x dropper is slow to return to full extension.. Would this just be air pressure, as it hasnt seen much use? The link to the race face one shows a air valve at the top of the post. I presume this is to add air pressure to adjust the return speed?
It could be the air pressure for sure. I'll track down a manual to see what air pressure you'll need and we'll see if we can make it work perfect again.
Prefer to keep mine,
One of mine was also. Added some air, sorted.
Anyone noticed any play in the seat clamp. Ie moving left to right and right to left about 10 degrees?
Just asking as I fitted mine today and there is a definitive movement. It’s not that big of a concern but it’s there.
The actual post doesn’t move just the seat clamp section
