Another random user
Cannon Fodder
Hello community,
As you can tell, I am new here so if I made any mistakes in posting this thread, please kindly point it out. Anyways, I recently purchased a hardtail MTB for around $250 from "Reid cycles". The bike itself when I assembled it looked sturdy with a seeming thicker than average frame and pretty good parts. When I attempted small jumps on the bike the chain would rattle a lot. Since I am very bored I want to take my bike down a MTB trail but I don't know whether the bike will be able to handle the impact of landing jumps and going over tree roots. I don't want to break this bike as I most likely can't afford another one. If I just need to replace the brake pads after every run I'll be fine with it, just not the whole front fork. Basically if I just need to make small adjustments or part replacements to make this downhill mountain biking ready, I'll be fine with that.
Specs:
Frame Material 6061 Aluminium Alloy
Fork Suntour M3030 27.5" 75mm travel
Gearing 21-Speed Shimano Tourney
Crankset Prowheel 24/34/42T Triple Chainring
Shifters Shimano Tourney EZ-Fire
Front Derailleur Shimano Tourney
Rear Derailleur Shimano Tourney
Brakes Promax Alloy V-Brakes
Brake Levers Shimano EZ-Fire
Hub KT Alloy Quick Release Front Hub, Shimano Nexus 3 Speed Rear Hub
Wheelset-Rim Reid Double Wall Alloy
Tyres Reid MTB 27.5" x 2.1
Chain KMC Z51
Freewheel/Cassette Shimano 7-speed Freewheel (14-28t)
Bottom Bracket VP Sealed Bearing
Handlebars Reid Oversize Alloy Riserbars
Stem Reid MTB 1-1/8" Threadless Alloy, Oversize
Grips Ergonomic Rubber
Saddle Reid MTB
Seatpost Reid Alloy 27.2mm Micro Adjust
Pedals PVC Platform, 9/16" steel axle
Weight (kgs) 13
Thanks in advance
Specs:
Chain KMC Z51
Saddle Reid MTB
Weight (kgs) 13
Thanks in advance
