Well, driving the car around, the low coolant light comes on. Hrm strange, let's fill it up a bit and see how it goes. Driving around for a month, all seems good.. but then finally the light comes on again. Damn, must be a leak somewhere. I do a bit of Internet research, turns out it's somewhat common for the plastic parts and seals in the V of the engine to let go around this time in their life... estimated repair cost is around $1800-2500... not because it's difficult but simply because it takes ages.
So I decide to attempt the fix myself. Order the parts from Europe, they arrive under 2 weeks later and one Saturday I start the job. It's going well, parts are stacking up on the garage floor. OK, now remove the fuel pressure sensor from the fuel rail. Hrm, needs a 27mm. I don't have a ring spanner that size, so I try the shifter... nope, it feels shit so I don't even bother. Dodged being a f-wit! Woo me. Ok, let's try the deep 27mm socket I have... fits sorta OK, let's send it. Grunt, heave, twist, crack. And not the good sort of crack, of a tight bolt coming loose. More the crack of a plastic housing saying farewell to it's home. Sigh.
I carry on, get the job done over a couple of weeks. Bolt it all back up, order a new sensor from Europe (cos they're $300+ here) and fit it up. Start the motor, it starts! But the CEL (check engine light) comes on and stays on
Scan the codes, no fuel pressure. Fuck. OK, so when I broke the original sensor the top came off revealing 3 tangs and 3 little springs making the connection. I lose one of the springs, but I dodgey something up with wire, put the sensor together and test it with the multimeter. Woo, it works! Superglue the fucker together, fit it to the car and the bastard runs, no CEL. Damn. So somehow the brand new sensor doesn't like the engine. So now I'm about to get bent over and enjoy the Australia tax on a new sensor.
Tally: massive f-wit points to me for owning a VW in the first place.
but bonus points for using an ill-fitting tool and snapping the top off an expensive sensor.
