ここには見るべきものは何もありません
Someone has had a busy day!
Are those spokes more for a 26 inch sized wheel ?
27.5"Someone has had a busy day!
Back again just to add to the above.My confession tonight is thinking I could change an inner and outer shift cable in 1hr.
Pulled the old inner out, ran the new inner through the old outer.
Pulled the old outer, started pushing the new outer up from the bottom. Spent a long time (with a few different techniques and much swearing) to finally get the outer through the CS. Hard part done.
Not.
Remove the downtube split cable glands, feed the outer up through the two ports. New outer is 5mm, old was 4mm. Split glands don't fit. Somehow manage to bore them out without applying drillium to my fingers. Small win.
Oh yeah, also put a 4m ID outer end cap on at the shifter instead of a 5mm one so had to pull the inner back out and put the 5mm one on.
Stop the clock! 3.5hrs
The best thing? The carpark test has shown I can't really even notice an improvement lolz.
Oh man. I haven't done that for years!Back again just to add to the above.
When I tightened the derailleur cable clamp screw before shortening the cable I forgot to wind the barrel adjuster at the shifter back out so I actually have some ability to adjust the cable. I left plenty of excess so no real harm.
Tonight's job is to wind the adjuster out and re-tension the cable.
Years for me too.Oh man. I haven't done that for years!
I reckon! An explosion would have definately tipped him over the scales to win father of the year though.Nothing caught on fire? No personal injury? This all sounds like a win!
That sounds a lot like my school reports "has done well, but could try harder".I reckon! An explosion would have definately tipped him over the scales to win father of the year though.
Those bloody lever covers! At least you didn't hook up the hose on both ends and bleed the brakes, then realise it wasn't even on the hose.Bike building on the weekend, including the rear internally routed brake hose. Had the original hose as a guide, taped the 2 end-to-end pulled the (new to me) brake hose and caliper through....
Fucking lever hose cover
Easy fix so I pulled the hose back though with the old one still connected.
Only problem was I pulled the old hose ALL the way through (and out) of the front triangle. Thank fuck it turns out the frame has internal tubes to make routing easier.
So doubly a fuckwit for also not realising this in the first place.
So fork goes gniob?Oh hey, back again.
New decals on my fork, installed one upside down
