Tank. Almost 24h now. Window probably closed.There’s the Samsung Galaxy Buds app which has a find feature not sure if needed to be set up prior or not. Is the poo tank a tank or soaker pit?
Yup, not worth fishing in a tank of poo.Tank. Almost 24h now. Window probably closed.
I can give you a link to a website where a “gentleman” will come around and not only hop in the tank and find the ear bud but throw you a few dollars for the experience- I suggest get the money first though for obvious reasons.Tank. Almost 24h now. Window probably closed.
You’ll have to quarantine, but thanks anyway.I can give you a link to a website where a “gentleman” will come around and not only hop in the tank and find the ear bud but throw you a few dollars for the experience- I suggest get the money first though for obvious reasons.
Why doesn't it surprise me, that you have such contacts?I can give you a link to a website where a “gentleman” will come around and not only hop in the tank and find the ear bud but throw you a few dollars for the experience- I suggest get the money first though for obvious reasons.
Sure, ‘contacts’.Why doesn't it surprise me, that you have such contacts?
Sorry, autocorrect. I meant contracts.Sure, ‘contacts’.
You will never do it again... from experience.Go to jamb the the valve through and it’s not going. That’s when I realised when I got distracted I moved my locating finger off the the valve hole and onto a spoke hole.
Sure. Welcome to this thread.You will never do it again... from experience.
The selection of the hole to cut/push the valve through will be methodical from now on.
The worst thing for me was I’ve always had ugly old tape. Electrical. Tried that. Gaffa type stuff. Bear brand not wide enough so you have to run around a couple of times and each tyre change makes it looks more raggedy so I was pretty excited when I saw this perfect width bubble free perfectly applied tape.You will never do it again... from experience.
Easy fix. Patch over the wrong hole with the remaining bit of Bear tape, then make the hole in the right place. You're only a proper fuckwit if you peeled the whole tape off before being made aware of the patching option......I’ve a minor tubeless tape one.
Had a new wheel built little while ago. Came with fancy muc off tape installed. Go to put the valve in, locate correct hole, get distracted,look away then look back and poke my hole.
Go to jamb the the valve through and it’s not going. That’s when I realised when I got distracted I moved my locating finger off the the valve hole and onto a spoke hole. That’s also when I realised my roll of Bear brand tape only had a few inches of tape left.
Yeah that’s what I did. So my nice perfect pink Muc off tape has a patch of blue. Do you even OCD man???Easy fix. Patch over the wrong hole with the remaining bit of Bear tape, then make the hole in the right place. You're only a proper fuckwit if you peeled the whole tape off before being made aware of the patching option......
Balance it on the other side and you are good to go.Yeah that’s what I did. So my nice perfect pink Muc off tape has a patch of blue. Do you even OCD man???
Never give up....Tank. Almost 24h now. Window probably closed.
Next time. I’m sure there‘ll be a next time.Balance it on the other side and you are good to go.
What did I just watch from start to finish?Never give up....
