Retaped? Because of tape failure - Only twice* after that 3M stuff everyone is now frothing over above literally just fell apart after about a year/year and a half. Luckily I’d double-wrapped the rim and the lower layer was still (mostly) holding air. I had another rim that had the same tape that had no issues though, so those two might’ve reacted with the soap I used when seating the bead back then. The old Bear stuff has been flawless on many wheels, but I’ve swapped a lot of tyres around different wheels so have damaged the tape a few times during doing that.
*I’m excluding the Spank rims with the “OohBar” rim bed, because (A) I was using “genuine Fratelli” (Spank) tape which was hard, non-conforming, and extremely low tack (ie: complete shit), and (B) because that lump in the middle of the bead profile is a mongrel for pulling the tape from under the bead down into the parallel valleys during tyre install and lifting the tape.
