Nothing a few paddle pop sticks and a wraps of tape can't fix. The flex should deliver close to a full inch of extra travel.It's longitudinal and almost certainly won't be an issue....
So why does the paint crack if there isn't an underlying issue?Lighter-coloured paints are less flexible than darker colours; they require more filler & pigmenting to get the necessary density. As I said, I've cut through that area of a returned frame and found no indication of deep damage; it's quite a thick section of tube with a complex layup, so each layer reinforces the others.
The duck may have a different answer to me but...the carbon flexes. It has give in it that is different to metal. You get the same thing with fishing rods. I loaded up at $1500 jigging rod (FYI - very expensive rod made for very abusive fishing) with a lot of weight in a shop a while back and holy shit did it make some noises! I thought it was about to ping...the shoppie assured me it was just the carbon layers moving around. Often after a bit of use you'll see cracks etc appearing in the clear coats on them as well where it isn't as flexible as the rod material (eg carbon).So why does the paint crack if there isn't an underlying issue?
Because the paint is a lot more brittle than the the substrate and doesn't need a great deal of movement to cause it to crack.So why does the paint crack if there isn't an underlying issue?Lighter-coloured paints are less flexible than darker colours; they require more filler & pigmenting to get the necessary density. As I said, I've cut through that area of a returned frame and found no indication of deep damage; it's quite a thick section of tube with a complex layup, so each layer reinforces the others.
So I have a car with plastic guards that deform when you push them, light colour, 7 years old spends most of its time in the sun. It hasn't cracked way more flexible etc than any carbon mountain bike component. I find it struggle to believe the paint would be that brittle, and if that is the case why don't they use a better paint?I would say paint crack... look at almost any plastic car body parts that have aged a bit and you will see similar cracking.
Colour may be impregnated in your fantastic plastic. Maybe we should anodised carbon?So I have a car with plastic guards that deform when you push them, light colour, 7 years old spends most of its time in the sun. It hasn't cracked way more flexible etc than any carbon mountain bike component. I find it struggle to believe the paint would be that brittle, and if that is the case why don't they use a better paint?
Alternatively how is there any paint left on the rear triangle of an Orbea Alma where the carbon is designed to flex in the rear triangle? Plenty of them getting around in light colours and they are old now.
No, they are sprayed fantastic can't be matched super duper pearly colour, looks pretty (not telling you what it is cause we will end up driving the same car). Still reckon the 'paint the is brittle' argument is flawedColour may be impregnated in your fantastic plastic. Maybe we should anodised carbon?
Maybe Giants normal painter was on holiday and they had to use the painter that Trek uses.~I find it struggle to believe the paint would be that brittle, and if that is the case why don't they use a better paint?
Ok wasn't the greatest example, but it does happen.So I have a car with plastic guards that deform when you push them, light colour, 7 years old spends most of its time in the sun. It hasn't cracked way more flexible etc than any carbon mountain bike component. I find it struggle to believe the paint would be that brittle, and if that is the case why don't they use a better paint?
There's usually several layers of clear coat over the carbon before the colour top coat, it's much thicker than the paint on a car.No, they are sprayed fantastic can't be matched super duper pearly colour, looks pretty (not telling you what it is cause we will end up driving the same car). Still reckon the 'paint the is brittle' argument is flawed
I hate when my foundation cracks. Geisha show?
Car bumpers etc usually have a 'paint plasticiser' added with affords a bit of extra flexibilityNo, they are sprayed fantastic can't be matched super duper pearly colour, looks pretty (not telling you what it is cause we will end up driving the same car). Still reckon the 'paint the is brittle' argument is flawed
Best answer so far.Maybe Giants normal painter was on holiday and they had to use the painter that Trek uses.
For this application beta tapes would be more suitable. Just sayin'.The duck may have a different answer to me but...the carbon flexes. It has give in it that is different to metal. You get the same thing with fishing rods. I loaded up at $1500 jigging rod (FYI - very expensive rod made for very abusive fishing) with a lot of weight in a shop a while back and holy shit did it make some noises! I thought it was about to ping...the shoppie assured me it was just the carbon layers moving around. Often after a bit of use you'll see cracks etc appearing in the clear coats on them as well where it isn't as flexible as the rod material (eg carbon).
But this is a crack. The only answer is to get your blow torch and a bunch of old vhs cassettes you don't need anymore. You know...the stretched ones. Heat frame with blow torch, melt vhs (tape and body) into the crack. Allow it to set over night and you're good to go.
No one has old beta tapes, but there are lots of VHS tapes in a box in the back of cupboards. For the same reason beta tapes never took off...For this application beta tapes would be more suitable. Just sayin'.
Well that does not look good. Will you still ride on Sunday? Got my entry in and really enjoyed this track last year. Hopeful rain just makes the course nice and grippy..Just had another passing look at the area before while in the garage and just noticed this on the other side (non drive side)...
Guess it certainly points to things not right.
Travis.
The track will be as wet as fuck. It was bad on saturday and we've had 15mm already today. It doesn't drain like the epic course.Well that does not look good. Will you still ride on Sunday? Got my entry in and really enjoyed this track last year. Hopeful rain just makes the course nice and grippy..
