Currently this is the most bang for buck upgrade you can do on the above forks. I'm quite surprised its at this pricepoint considering its SRAM.
Would be interesting to see someone do a Debonair vs Luftkappe comparison on the same fork, but in reality probably 90% of riders won't be able to tell much of a difference (including myself) as they achieve a similar goal, but just through a different path.
quote from a user on pinkbike forum:
"The luftkappe gains its negative volume by expaning into the positive chamber. The debonair gains it through some reworking of the stanchion plug and a hollow shaft. So the luftkappe has a more progressive curve (i believe they say its simllar to two tokens). The luftkappe i think still has a stronger negative spring, no math to back that up but since the dome is now acting as the piston and there is no rod attached to the dome ther should be more area, pressure over area and all that. also the luftkappe tops out pnuematicslly, no top out bumper, probably part of having more force.
Both seem to have their pros and cons. I can say my debonair upgrade was really nice improvement for my 2018"
