In fairness, you had to crash into the Pinto for it to explode.At least it's better than a Ford Pinto!
That's a surprising comment from an automotive executiveBMW executive says motorists should stop buying new cars
A high-ranking BMW executive has encouraged motorists to spend their money on rejuvenating used cars instead of purchasing new vehicles.www.drive.com.au
Probably a good idea given BMW's current design direction.
Thats not always true. Its not even often true... Lots of asterisks on those assessments.Even though newer cars are more efficient, it is far better to keep old cars running for as long as they reasonably can be.
Do the new packs have anything done about the rubbish cooling?It's an interesting dilemma, and one I am currently exploring. I own a Gen 1 Leaf, which has done 100K. Battery currently at 75% capacity so a realistic winter range of only 75km. The rest of the car is fine, everything works, interior in good nick, and minimal rattles. This batch of Leafs were made in Japan and aside from the battery degradation are know for being very reliable and well screwed together, lots of reports of cars doing 300K plus OS with battery swaps.
There are after market options coming online in Australia, currently in contact with with a bloke in Melbourne who is quoting a replacement 62kWH battery (almost 3x capacity of the original 24kWH unit, so probably 350km range) of $20K using CATL modules, same as currently being installed in a lot of Chinese EVs. Realistically with transport to and from Tasmania, and would probably need stiffer springs installed as the battery casing apparently projects lower than the original, would probably cost in the range of $23K all up. New cars with that size battery start at $50K (BYD), so it's basically half the price.
If I could get it done locally, and get to keep the old battery which could be converted into house solar storage it'd be a no brainer, especially since junior is only a few years off his L plates so would be a very cheap car to run for him. Otherwise do I just go for the new battery and hope that the rest of the car holds up?
I've seen various studies that do say that keeping a well maintained car to its full lifetime is better than just disposing of them every 10 or so years.Thats not always true. Its not even often true... Lots of asterisks on those assessments.
Exactly - "full life", "10 years". You can push the assumptions around to get the answer you want. Also obviously depends on what youre replacing with what.I've seen various studies that do say that keeping a well maintained car to its full lifetime is better than just disposing of them every 10 or so years.
Keeping old cars longer can help the environment MORE than buying new electric cars - Study Finds
When Used Cars Are More Ecofriendly Than New Cars - Scientific American
AFAIK those cells don't really need it, especially with the much larger pack driving the same small motor and inverter.Do the new packs have anything done about the rubbish cooling?
No, but a) that's not an issue in Tasmania, and b) it was only really with the first generation of battery chemistry in hot climates where it was a real problem. The newer chemistries are much more heat tolerantDo the new packs have anything done about the rubbish cooling?
In that case the only real argument for not spending on it is if the body etc is rough or you feel the safety suite etc is outdated. Given thats probably a no, then may as well keep it going.No, but a) that's not an issue in Tasmania, and b) it was only really with the first generation of battery chemistry in hot climates where it was a real problem. The newer chemistries are much more heat tolerant
Yeah, that's what I reckon. Body fine aside from a couple of home panel beater fixed dings thanks to the missus and safety wise it's got four airbags, ABS, EFD, traction control etc so it's really only missing the modern fruit salad alerts such as cross traffic, lane keeping, blind spot, front collision warning blah blah which have frankly given me the shits when I have driven cars with them installed.In that case the only real argument for not spending on it is if the body etc is rough or you feel the safety suite etc is outdated. Given thats probably a no, then may as well keep it going.
Given we are looking at more than half that sort of coin to reinvigorate (rebuilt engine, rebuilt gearbox and front diff, new clutch) the original driveline of a turn of the century one owner Subaru Forester with a bit over 300k on the clock...I'd say go for it.Yeah, that's what I reckon. Body fine aside from a couple of home panel beater fixed dings thanks to the missus and safety wise it's got four airbags, ABS, EFD, traction control etc so it's really only missing the modern fruit salad alerts such as cross traffic, lane keeping, blind spot, front collision warning blah blah which have frankly given me the shits when I have driven cars with them installed.
Agreed the new battery chemistries don't seem to degrade any worse than a Tesla or many others but it still is a fast charging issue (aka rapidgate) EV's enhanced in NZ are just starting to produce a liquid cooled LFP pack that would deal with everything. Having said that I'm sure you aren't doing laps of Tasmania in the leaf so doing more than 400km in a trip regularly is probably not an issue.No, but a) that's not an issue in Tasmania, and b) it was only really with the first generation of battery chemistry in hot climates where it was a real problem. The newer chemistries are much more heat tolerant
Is that the suv one? Shame the nameplate got bastardised by SUVing it... There is not really anything French left that appeals these days, sad theyre just making boring suv clones after a long history of innovative and interesting designssaw a left have drive renault megane EV out testing yesterday. they did say the RS line would be electric but this was a normal family hatch version. be nice to see more regular sort of cars that happen to be electric. I wonder how well they can make a smaller car handle if they remove half the batteries and weight.
...that lost money and caught on fire.Is that the suv one? Shame the nameplate got bastardised by SUVing it... There is not really anything French left that appeals these days, sad theyre just making boring suv clones after a long history of innovative and interesting designs
wasnt particularly high riding but a lot more blocky than the current meganeIs that the suv one? Shame the nameplate got bastardised by SUVing it
Huh?...that lost money and caught on fire.
