I haven't ridden the new 34's so can't comment.Way to unleash the @beeb…
So which spec Mezzer are you buying? This is one of the most productive threads ever on Rotorburn!Let’s be honest. Buy the end of this thread I’ll be buying another mezzer or a bomber
Would love another mezzer pro LeSo which spec Mezzer are you buying? This is one of the most productive threads ever on Rotorburn!
This is now a serious contender. Having run an r7 pro and knowing how stiff they got that fork, these would surely be a good thing. And well look at that silver blingNew Mattoc Pro. End thread.
You’re a human Bower bird. You just can’t resist.This is now a serious contender. Having run an r7 pro and knowing how stiff they got that fork, these would surely be a good thing. And well look at that silver bling
Anytime you’re willing to part with that pretty Loam Lab stem it’s all yours old cock.Ha ha don’t you know it. Now where is my silver i9 stem
Be interested to here how you find it.I'm testing out a mezzer at 140mm, I'll let you know how it goes. I'm not convinced it'll be any good with the reduction in travel but time will tell.
I’m sure they are all great forks and will definitely out perform me. This time I’m going to stick with 140mm as recommended. I have a pike and it’s a great fork. The only experience I have with 34s is stepcast at 120 (had a couple and liked them and an old CTD 150 that I upgraded to fit4 damper and air spring, compared to other forks this does feel flexyI’ve not had any problem with RS warranty work or dealing with the importer but Fox was a nightmare.
Pikes are a good 140mm fork. Manitou will also be nice.
Can’t go wrong with any of them when they’re working as designed imo.
The Pikes on the 5010 and Nickel are at 140mm. A few generations apart, but both are pretty good forks for trail messing around. Can't say I'd need much more from them at all. Both have an MRP Ramp Control and the older Pikes also has a Luftkappe. Bolt on pimpage.I’ve not had any problem with RS warranty work or dealing with the importer but Fox was a nightmare.
Where early 32s a fork, I thought they were a pool noodle. My old 150 34s are a lot better but not as good as my pikeThe Pikes on the 5010 and Nickel are at 140mm. A few generations apart, but both are pretty good forks for trail messing around. Can't say I'd need much more from them at all. Both have an MRP Ramp Control and the older Pikes also has a Luftkappe. Bolt on pimpage.
I guess it all comes down to where you will be riding and if you need moar fork.
I would like to do a bakeoff between the Fox 34 or 36 and Pike Ultimates. You really need to compare but hard to have that luxury. I've always had Fox forks and the Pikes were my first RS since the Quadra 5s and a brief run with the Revelation dual air on the TRc - which were great trail fork overall but did get rigid after fast chunky oil cavitating descents.
I do like that the Pikes seem to suppress the trail chatter well and seem to happily ride lower to midway in their travel. My earlier Fox seem to use more travel overall to absorb bumps while RS seem to dampen it more while using less travel *. They do feel pretty well sorted and controlled for my nancy riding anyhow. Having a fork that I can service myself is also a factor for me.
All forks now are pretty well refined. I think it would be hard to mess up royally with any choices from RS, Fox or Manitou. They are just a bit different.
* Disclaimer: RS 35mm with Charger vs. earlier Fox 32mm open oil bath is never going to be fair to compare. Oh well.
The 32s have a bit of flex but the QR is a big part of it. The Pike sure feels stout for much the same weight as older forks.Where early 32s a fork, I thought they were a pool noodle. My old 150 34s are a lot better but not as good as my pike
And it’s Fucking SHINY! Cmon.The Charger3 in the new RS stuff would appear to be crap based on the interwebs. I have not owned or ridden one. I had a Pike with Charger 2.
Like @Jpez says my first pick would be the Mattoc Pro. Its got a proper damper, good adjustable air spring and the weight is competitive. Second choice would be the Fox 34 with Fit4 (or perhaps Grip2).
