Update; Surgery went well I was in and out in the space of half a day.
Collarbone is now back in one piece!
Before:
After:
First day post-op was fairly horrendous with pain. The pills were pretty good but had to eat a lot of prunes, if you know what I mean. One noticeable improvement was the tension in the upper back disappeared as now the shoulder was in the right place.
Second day was not too bad and no longer had to rely on the pills.
By third day I felt good and was back to work, had arm out of sling whilst at the computer etc. Also started some mobility exercises.
By day 5 I think I pushed a bit too hard and the shoulder was getting sore. The muscles were all crapping out and seizing up. Back in a sling for most of the day hereon to provide more support.
Just got back from Physio yesterday and nearly fell off his chair when he saw how much my upper back muscles had wasted away during the 3 weeks of being in a sling. Every other muscle I had remaining on that side was over stressed from compensating for the broken collarbone, and were giving off crazy spasms after now being stretched back in the opposite (correct) direction after surgery. Shoulder joint was stiff and can't lift my arm higher than about chest height.
So doing some more mobility work now until post-op appointment with the surgeon whereby he might clear some light stability work.
So the moral here is... If you think you need surgery then decide early and get it done asap. Every day you keep the arm immobilised is going to stiffen up the joints and waste away your muscles. There are exercises you can do with your wrist, elbow and fingers etc which don't put any stress on a broken collarbone and these should be commenced pretty much within a day or two of the accident.
More to come..
