DaGonz
Have you ridden Majura since then with this config? how did you find it?Then I swapped the medium for a narrow.
This was only because of the long descents /long fire-road at the Stromlo 24hr.
Cheers
Gonz
No I haven't,Have you ridden Majura since then with this config? how did you find it?
Cheers
Gonz
Want to buy cheap lights, buy some of the luxeon III's from Ay up they are old stock that they are getting rid of for $45 each, no battery's though. They run off 7.2V I have brought 2 sets of my wife and run them off my 14.4V battery's I have for the vicious just ran them in series. She has to have both on but they work well ver bright for a $90 light.
I had a chance to compare a lumin8r Led vs the later_but_not_Q5 Ayups. Light wise, the ayups wern't really in the same league basically. Did the job, probably value for money, Not the light nirvana I would be looking for.Anyone had a chance to compare these 3 lights? Especially since AYUP is now using the Cree Q5s like the Lumen8R does.
Yeah I guess 2 sets is 4 lights (each set comes with 2), My wife mainily commutes with them they would be enough for off road but not quite for racing. If she does end up racing with me which would be in a team she can use my HID well she could actually have the HID and 4 luxeons on her hemet if she wants .I was just checking the Ay Up site, looks like some good stuff there, when you say you got 2 sets for your wife, are you talking 4 lights
What sort of trails is your wife riding?
Decisions decisions!
In theory, it looks as though the Lumen8R is going to produce about 768 lumens - 3 leds producing 256 @ max of 1000ma.I had a chance to compare a lumin8r Led vs the later_but_not_Q5 Ayups. Light wise, the ayups wern't really in the same league basically. Did the job, probably value for money, Not the light nirvana I would be looking for.
HTH
Cheers
Gonz
whats the pricing on these 3 systems just to act as a guide?Hey all
From the data sheets from Cree and SSC the relative outputs would be:
Lumen8r LED - 3 x Cree Q5 - 3 x 228lm @1000ma Total of 684 Lm
Nightlightning - 3 x SSC P4 - 4 x 240lm @ 10000ma Total of 720 Lm
Ayup - 4 x Cree Q5 - 4 x 140 @ 500ma Total of 560 Lm
I have just brought the Lumen8r and am waiting for delivery. the reasons I used to decide were that you cant adjust the angle on the nightlightning unit so it has to sit well on top of your head. Also the Lumen has been designed to be upgraded later, Cree have already released a R2 LED (270lm) and have other releases planed... It seemed to me that there is likley to be a nice upgrade path for this unit above the auyps. I have not seen any info on new releases fron SSC. I know Nightlightning are making a 4Led system and a dual 3 led system but the money and weight didnt stack up.
Any thoughts?
$455 - Lumen8Rwhats the pricing on these 3 systems just to act as a guide?
DIY!!For about $200 or so, what's the best choice?
The Ay ups are too expensive, starting at ~450
You're not kidding. Brett and I bought some R2 Crees to fit into our old halogen lights. We've done Brett's with a 3xR2 and are doing mine with a 4xR2 tonight. It's certainly a big step up on 20W and 35W halogen, and on the numbers should compare favorably to HID tech and Nightlightning's LED lights. Time and a side by side comparison will tell .DIY!!
These are about $240-250 for a pair of doubles inc lights, batteries, charger and put out more light than the AYUPs. You could even do it cheaper by making a single, triple or quad LED light.
http://forums.farkin.net/showpost.php?p=978577&postcount=121
http://forums.farkin.net/showpost.php?p=1008284&postcount=158
Also check out the 'Budget XC Lights" thread: http://forums.farkin.net/showthread.php?t=122694
I went for a set of cheapie halogens from Torpedo 7, what a waste, they were horrible.. useful for riding along an illuminated concrete bike path but not for single track MTB. I then ditched them to a mate who persisted for 3 months and then got a set of Ay Ups as well after seeing mine in operation. The cheap ones were a waste as they were useless, the AY UPs are brilliantFor about $200 or so, what's the best choice?
Erin, care to elaborate on how you retrofitted them into your old lights?Put the 4xR2 bin Cree light together tonight
DIY!!
After reading your's and a few other threads ive decided to go down the DIY path. Most people seem to be having a fair bit of succes so thought it was worth a shot and cant go wrong for the price versus buying a setup.
Will be making something very similar to yours, starting with 2 sets for the helmet, one for me and the other for my girl and see how they go. If they work out well may make 2 set for the bars later on and try some different optics.
Would you recommend those 7.2v battery packs and smart charger are the way to go for power?
Parts i have ordered so far:
4x CREE XR-E R2 bin (WH tint)
2x Ledil CREE XR-E CRS-M 14 degree square optics
2x Ledil CREE XR-E CRS-D 9 degree square optics
2x 3021 BuckPuck 1000ma drivers
Anyone got some ideas on where i can get some reasonable universal helmet mounts from?
Still havent quite worked out what im gonna mount the Led's in yet but will probally use some 25mm square bits of aluminum tubing or a pre made aluminum case from somewhere.
Are you running the Crees in series or parallel? If you are running them in series you'll need a >18v battery pack. EG a 5 cell lithium pack or 15 cell nimh pack. If parallel those batteries would be perfect, but I believe the driver would be running each LED at 250ma, which is not very bright.Would you recommend those 7.2v battery packs and smart charger are the way to go for power?
