STS01
You need to provide 3.7v to each LED plus about a volt for the driver so If you're intending to make doubles you'll need 9.6v batteries, triples will need 12v (but preferably 14.4).After reading your's and a few other threads ive decided to go down the DIY path. Most people seem to be having a fair bit of succes so thought it was worth a shot and cant go wrong for the price versus buying a setup.
Will be making something very similar to yours, starting with 2 sets for the helmet, one for me and the other for my girl and see how they go. If they work out well may make 2 set for the bars later on and try some different optics.
Would you recommend those 7.2v battery packs and smart charger are the way to go for power?
Parts i have ordered so far:
4x CREE XR-E R2 bin (WH tint)
2x Ledil CREE XR-E CRS-M 14 degree square optics
2x Ledil CREE XR-E CRS-D 9 degree square optics
2x 3021 BuckPuck 1000ma drivers
Anyone got some ideas on where i can get some reasonable universal helmet mounts from?
Still havent quite worked out what im gonna mount the Led's in yet but will probally use some 25mm square bits of aluminum tubing or a pre made aluminum case from somewhere.
As for the optics, I think mediums (CRS-M) are too diffuse. The CRS-D (diffuser) is perfect for a 'spread' beam while the 'smooth spot' is a good spot beam. To give you an idea, I run 2 diffusers on the bars and one smooth spot and one diffuser on my helmet. Running 2 smooth spots on the helmet would be OK if you like a more focussed beam.
